Home > Maintenance & Modifications > Home made transmission oil filler
Siwynne
Last time I changed all fluids I found it hard to fill transfer and from below. I set about collecting the necessary to make a pressurised filler. I scrounged a pressure cooker and some other bits of pipe and a tyre valve. After drilling some holes in the lid I fitted the valve and feed pipe. Tested and works a treat. Simply put the correct volume of oil in the pan and blow into the correct hole on the truck.
Post #723235 13th Aug 2018 4:08pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Laughing love it! Bow down 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #723238 13th Aug 2018 4:12pm
gilarion
So do I Thumbs Up Ingenuity at its best. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #723240 13th Aug 2018 4:19pm
zsd-puma
well it's clever, and probably easier than an oil syringe. but I can't help thinking just using a garden sprayer with the end chopped off the pipe would do the same thing.
https://www.screwfix.com/p/sx-cs5-white-bl...0wod41AE-A
Post #723339 14th Aug 2018 12:38am
ian series 1
Overall you will find it hard to beat one of these,
Makes filling diffs and boxes effortless.
Wouldn’t be without mine,
but 10/10 for the pressure cooker idea Laughing
 80" 80" 86" 88" 90"
Post #723355 14th Aug 2018 7:11am
Siwynne
Garden sprayer works. I enjoy making stuff and this cost me nowt as I scrounged the pan and had all the other bits. That Castro’s pump is a great looking bit of kit.
Post #723368 14th Aug 2018 8:55am
Caterham
do you have to put the pressure cooker onto a pre-heated stove for it to work?
Post #723380 14th Aug 2018 9:37am
I guess it would thin the oil and make it easier to transfer!
You could bung some chips in the leftover too.
Post #723410 14th Aug 2018 12:12pm
^^^^ Rolling with laughter ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #723417 14th Aug 2018 1:09pm
williamthedog
Only if it was high in polyunsaturated fat and low in saturated fat though Rolling with laughter Rolling with laughter Rolling with laughter
Post #723428 14th Aug 2018 2:14pm
