Home > Technical > is my clutch kaput?
22900013A
is my clutch kaput?
Noticed on Friday that my gearchange seemed "notchy" and occasional strange "chewbacca" noises when changing gear, but everything seemed to pull okay. Coming home today and situation definitely has got worse. I found things were alright if I double-de-clutched, gear change worse going down gears than up. When in sixth all okay until about 55mph, if I push pedal harder after that it pulls okay but makes a strange noise. When I got home I could not engage reverse gear to park up, gt it into reverse and bite point was right at bottom (ir pedal fully down and truck still moving) and making a weird noise. Clutch fluid level is fine. The truck has done just shy of 80K miles on original clutch.
Any ideas? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #723078 12th Aug 2018 5:55pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
If my Landy ever made a noise like Chewbacca, I will jump out and run.
But seriously that is the weirdest explanation I've ever heard.
Post #723086 12th Aug 2018 6:30pm
80k on original clutch 😯 My first gen clutch went at 42k!
There are a lot of theoretical possibities but it would really need looking at. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #723092 12th Aug 2018 6:37pm
22900013A
I suppose I mean like a groaning sound... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #723100 12th Aug 2018 6:55pm
leeds
Could well be the springs in the clutch which has gone kaput.
LR has done an uprated slave cylinder from VIN FA459934. If yours is pre that you might need an adaptor if you replace slave cylinder.
Have a look here . We send them all over the world, last week it was Italy and Zambia.
Brendan
Post #723118 12th Aug 2018 8:44pm
DAZ110
Yep, sounds like your clutch plate springs are beginning to fall out of the plate.
My previous 110 had the same symptoms you are describing.
Post #723125 12th Aug 2018 9:17pm
22900013A
It is at the garage now so I'm awaiting the call once they know whats up with it. I guess at seven years and just shy of 80,000 miles I can't complain too much as this is the only time anything has actually gone wrong with it! 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #723288 13th Aug 2018 8:44pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
" ... as this is the only time anything has actually gone wrong with it!"
Bl00dy hell, that's a first. Laughing
I had a Vauxhall Astra once that did 247,000 miles without a hiccup. When I came to change it I ended up taking it to the scrap yard as it was worth more there than selling in the local paper / eBay. Rolling Eyes
Hope you get it sorted and it ends up being resolved at a reasonable cost.
Andy
Post #723329 13th Aug 2018 10:42pm
22900013A
We already know its going to be looking towards a four figure sum without perhaps actually getting there...we shall have to see. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #723359 14th Aug 2018 7:28am
22900013A
Turns out it was clutch springs. :/
New clutch, slave and flyhweel all gone in now.
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #726084 29th Aug 2018 4:41pm
