Home > Tdi > Rear springs for 110 200tdi |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
Simple answer is yes. As far as I am aware all 110 rear springs are interchangeable from 1983 through to 2018. When I rebuilt my 1983 110 6 years back I fitted new take-off springs from what would have been a 2012 model. They were the progressive wound Purple/Brown ones known as the HD spring. The Yellow/Green/Yellow springs fitted to the Utility 110 are supposedly a little bit softer, though still progressive, so may be batter in your case.
Edit, google suggests that the rbk101111 springs are the purple/browns I have on mine |
10th Aug 2018 10:54pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
rbk101111 will fit but they'll be harsh. I have them on my mostly unloaded SW and they're too uncomfortable. I'll likely go to the green/green/white at some point. When you have 800kg of sand in the back though they're beautiful
11th Aug 2018 8:27am |
Green/green/white is rkb500300 by the way, as mentioned above
11th Aug 2018 8:30am |
