Home > Puma (Tdci) > Puma 2.4 Loss of accelerator pedal response (for 15 sec)
Harald
Belgium 2010 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
Not really a new topic, but I still would be interested in your opinion about a problem I have.
This month our 2.4 2009 Def started having problems with the acceleration pedal.
The stuped thing is it happens at (almost) the exact spot on the highway....
Attached some measurements.
Problem starts at 90 sec and ends at 115 sec.
As you can see at that point fuel rail pressure starts dropping stepwise.
Also the turbu pressure 'goes down'.
As I learned from the forum that it could be an engine temperature related problem I also measured the engine temperature, which I think is pretty hot Sad.
And it seems that the problem start as soon the engine temperature goed above 110 degrees Celcius.......
Could I be on the right way, and....what could cause the high engine temperature?
The cooling hoses at the back at the engine are (due to a leak) replaced a month ago, could it be an air related (bleeding NOK) problem?
Any suggestions are more than welcome.
Post #720591 31st Jul 2018 5:54am
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Your problem is 99% related with the engine temperature.
In my case the cut off happens at 115 deg but in your car it can be 110.
Now, good luck finding out what is the problem and don't forget to share the solution Smile
Here you will find some tips:
http://www.defender2.net/forum/topic56815.html Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #722607 9th Aug 2018 11:17pm
Harald
Thnx Bergos, Did you finally solve it with the belt change? So far I replaced the thermostat (For a 82 degrees opening version). I also mounted the visco-fan extender. The stupid thing is now the engine even heats up more.....and faster. Normaly it was only with +30 ambient temperatures on the highway (120 kmh) I had the problem. Now I have it already after a 7 km drive from home ( ambient temperaturen about 20 degrees, 80 kmh). Frustrating! Now I want to put the old thermostat back to see of there is anu difference (I checked it with hot water, thermostat opened).
It is a long list what could cause the overheating, at least in my opinion:
Leak in cooling system (had that, changed coolant hoses)
Thermostat (changed)
Visco-fan (föhnded it yesterday with hot air, didn't feel any difference in torque increasement when turning it......
Water pump
Radiator (cleaned it from the outside, no difference).
Head gasket
Egr cooler (when leaking blowing exhaust gases in the coolant).
Water pump can hardly be tested when mounted on the engine.
Post #722614 10th Aug 2018 1:57am
Bergos
Your symptoms are not good Sad
At 120 deg head temp. your engine should actually shut down. This happened to me only once when I let the coolant reservoir open and the fluid was blown out.
In my case changing the belt helped. No I rarely exceed 100 deg while driving 120 km/h uphill. Sometimes it goes to 105-110 deg but goes down to 88-92 very fast after the uphill.
For me it is still a bit strange but "people say" that it is normal.
I have also completely removed the stupid EGR.
Good luck! Bergos
Post #722615 10th Aug 2018 2:33am
Harald
At 112 degrees (calculated) coolant temperature the engine went into 'high temperature protection mode'.
Post #722617 10th Aug 2018 6:32am
Bergos
The important temperature here is the Cylinder Head Temperature. The threshold is 115 deg. Bergos
Post #722644 10th Aug 2018 10:25am
Harald
When you look at the Printscreen the CHT is 120 degrees, calculated coolant temperature is 110 degrees. At a calculated temperature from 112 degrees the protection mode kicks in (no gaspedal response). Exact values probably vary a bit depending on the OBD tool you use.
Post #722646 10th Aug 2018 10:48am
Could it be as simple as a faulty CHT sensor?
Post #722650 10th Aug 2018 11:14am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
You probably have an airco. Because this problem only happens with aircon models.
I had the same problem as you. Finally I solved it by replacing the radiator with a bigger one. First i also tried the temp 82 degrees and the visco fan extender. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #722652 10th Aug 2018 11:19am
Bergos
It could and it's worth checking this in the first place but I would not hope it's just this Sad
In this case the first thing to do is a block test.
https://www.youtube.com/watch?v=7Rwip1aCNF4
If the block test turns out to be positive (exhaust gas leak confirmed) I would block the EGR at the exhaust manifold, before the EGR cooler and repeat the test.
If the second test is positive you need to repair your engine or replace it whichever comes cheaper. Bergos
Post #722656 10th Aug 2018 11:24am
Harald
Yep, I have airco. EGR is closed ( by hardware and software). Stil have to do the CO test
Post #722659 10th Aug 2018 11:39am
Harald
Faulty cht sensor is possible. However I checked mine at 20 degrees and at 100 degrees (static test). Values were OK. The nummer of the old model cht sensor changed ('Microcat).
Post #722661 10th Aug 2018 11:41am
Harald
The cylinder head leakage test seems to be OK.
Blue means no CO.
However...I don't feel much difference in visco fan resistance whether the engine is cold or hot.
Visco fan can easily turned around by hand.
Anybody who checked his visco fan this way, could you really feel the difference?
Post #722836 11th Aug 2018 12:40pm
Bergos
The visco will turn slowly for a while and should engage when it gets hot, usually with the hot air coming from the radiator.
Until it engages it can be easily stopped by hand. After - don't try to touch it if you like your fingers.
Drive the car for a while, stop it, open the hood and try to stop the fan with a rolled newspaper. If you are able to stop it, you need a new visco. Bergos
Post #722875 11th Aug 2018 4:53pm
jst
When she Is hot, stop, open bonnet , you will be able to hear the viscous locked up and feelbthe draw and rearward movement of air.
After then stopping the engine check fan resistance, I would suggest , it shoukd be hard to turn by hand, if it spins freely its goosed. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #722890 11th Aug 2018 6:28pm
