![]() | Home > Puma (Tdci) > oil which one |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
It is a 5W30 but viscosities (40&100�C) are a bit out of range. TBN is a bit low I think. Puma 110" SW
Happytiger Member Since: 14 Aug 2009 Location: Hawkes Bay Posts: 3 ![]() ![]() ![]() |
Hi, I agree with the 0W-40 or 5W-30. mine (2008 Puma) is running well on a full synthetic 5W-40 (normal SAPS) which meets WSS-M2C-913b.
BUT: First thing to do, depending on where you are in the world is to see if it has a diesel particulate filter (DPF) fitted. THis is the key question (They dont fit them in New Zealand to the Puma) because it steers you down one of two paths (a) Normal SAPs oil or (b) LOW SAPS oil (this is the additive package). If a DPF is fitted you MUST use a low SAPs oil, which is a ![]() If you have to use a LOW SAPS oil then you are into Castrol products such as Longlife 111, and SLX Professional OE, and the best of luck to you !! Once you have sorted out the DPF question and thus the SAPS question you can make your choice of viscosity, synthetic vs mineral base etc. If you think this is confusing ...beware...most of the trade dont understand it either, try asking your local Landrover Service Manager for a full data sheet on the oil they just poured in...yeah right !! THis is a case where "most modern" is definitely NOT the best. Cheers...Richard 2008 Puma Defender XS 110 2010 Skoda Superb Combi 2.0 TDi 2006 ZX14r Kawasaki (Hyperdrive Travel) 2010 Suziki Burman 650. Sunny Day Scoot Slowly Recovering Discovery Owner |
Agree. For me normal SAPS, low visc and upper end HTHS values (ie. 3.5cPas). As close as possible to a SL-CI rated. Puma 110" SW
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2674 ![]() ![]() ![]() |
I am not aware of any 5w40 which meets this requirement - what brand are you using? ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Ah, well thats where we antipodeans have an advantage, we have an oil specialist company called PENRITE based in Australia, which has probably the best website and lubricant resource of any lube company out there. I use Penrite HPR Diesel 5W-40 Synthetic (meets WSS-M2C-913-B). PENRITE are what Castrol used to be before BP got them - obsessed with oil and lubrication. But remeber my Puma does not have a DPF fitted so I can use standard SAPs oils.
Cheers Richard [/u] 2008 Puma Defender XS 110 2010 Skoda Superb Combi 2.0 TDi 2006 ZX14r Kawasaki (Hyperdrive Travel) 2010 Suziki Burman 650. Sunny Day Scoot Slowly Recovering Discovery Owner |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
penrite.uk@penriteoil.com
Tel: +44 (0) 1594 562357 The U.K. CONTACT DETAILS FOR PENRITE. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
My dealer put Mobile 1 FE 0-30 in mine - fully synth
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
I have used semi synthatic mobil 10w 40 with ACEA A3/B3 and the engine runs 100% normal with no change what so ever. My country, it is very hot and humid through out the year!
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
For the non DPF vehicle, Castrol Magnatec 5W-30 for the UK which is a fully synthetic M2C-913B oil.
For the DPF vehicles, Castrol Edge or any oil which meets the Ford M2C-934C. I was talking to a dealership manager a few days ago. A Discovery3 down this way on holiday broke down and was recovered to one of our local Dealership workshops. The engine had failed, warranty procedures started but Land Rover refused because the oil was not correct (and last filled by another Dealership ![]() ![]() TOPIx now has several lubricant sections for the newer vehicles in the Vehicle Spec Book. https://www.defender2.net/gallery/albums/userpics/11134/en_GB.pdf |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
the manual recommends Castrol magnatec A1 5-30. This meets 913A, B and C and was apparently made specifically for Ford TDCI engines. Its also quite cheap and is (now) classified as a fully synth so why not just use what it says on the tin and change it frequently ?
I am sure some defender puma owners who do not have LR warranty anymore, do not use exact same spec oil and has anybody heard any engine failure due to incorrect engine oil? Unless you use something really weird and bad and not suitable at all.
The reason I went with semi synthetic mobil 10w-40 with ACEA A3/B3 is that we don�t get 5w-30 here and if it is available they are very very expensive. Since I have put semi synthetic, I will change the oil after 5000km and also the oil filter. ![]() |
Take a look at this video - particularly if you do anything in the cold - personally I'd stick with fully synth
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Yes, great oil but does it meet the Ford specification? I suspect it does but there is nothing on the Opie site to show it.
