![]() | Home > Puma (Tdci) > Rattling clutch, transfer box leak |
| yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200
The vehicle is MY07 with 45k km on the clock. Symptoms:
- two days ago I have realised like something was rubbing while driving - squeak, squeak, squeak... more frequent than wheels revolutions - yesterday disengaged clutch stared to rattle while driving (till now I didn't know what you guys mean by 'loose spanners rattle' - now I know - today I have looked under the vehicle and saw leak at transfer box (see the picture) I have changed the T-box oil week ago to Valvoline HP 80W-90 GL-5 (as well as other fluids) at independent garage. Can it be that something was done wrong during fluids replacement? Can you suggest what parts need replacing / fixed to cure it?
Cheers! Janusz www.yahodeville.com |
Second part of the question: can I drive the car in the meantime or do I risk further damages? Janusz
I am 200 km away from the garage. Janusz www.yahodeville.com |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
probably you can reach the shop. The rattle comes from the natural noise produced by the input-output shaft of the gearbox (typical on diesel engines) which is not dampened anymore by the central damper of the friction plate. I would just not demand a lot of torque., ie do not do full throttle when under 2000 rpm. Of course do it at your own risk. Good luck
Oil leak: How much oil did they use? Clean it and spot the source of the leak. You have also a leak on the rear of the Tbox (there is a service call about it) Did you exchange the clutch already? Or still on the old version? ............................................................. Earth first. Other planets later |
Thank you for the answers
I will go to the garage on Saturday. I do not know how much oil was filled - it was done by guys experienced with Patrols, Discos, Cheerokees so I assume they did it right with Defender. Tbox leak - is it "Park brake oil contamination" call or another one? The clutch is old version, my car was born Feb 2007 and still on the 1st clutch. New clutch kit is on the way. Janusz www.yahodeville.com |
Check the level: it is 2.3 L, reaching just under the filling hole (but I do not think it is the problem). But your main leak comes from the front of the Tbox. On the right side and top of the Tbox there is breather with a small hose. Check it is on. Puma 110" SW ............................................................. Earth first. Other planets later |
Can you recommend a supplier selling latest version of the clutch?
I have bought one already which supposed to be new, but it was not (manufactured March 2007). While I have returned the part, this time I want to be sure it is new one. Unfortunately none of five suppliers I have asked have replied to my inquiry. Cheers! Janusz www.yahodeville.com |
Try famous four. They will answer to your questions. Puma 110" SW
| ter11 Member Since: 28 Oct 2015 Location: Zurich Posts: 26
Dear all
My Defender built 2007 with now approx. 45k km on the odo has developed the same exact issues. Probably I will need to have the clutch replaced soon. I would be particularly interested in the oil leak issue: a first check under the vehicle confirmed that oil is leaking fron the backside of the transfer box. How did you people solve this issue? Best Ter |
| All times are GMT |
