Home > Td5 > Wheel Wobble! |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Swivel bearings, check the preload on either side,
Also check TREs 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
2nd Aug 2018 2:22pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Steel wheels or Alloy? If steel then the loose nuts could have resulted in the wheel nut holes becoming ovalled and the wheel no longer centralising on the hub.
Also make sure the wheel mounting face and the back of the wheels is spotless. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
2nd Aug 2018 3:08pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
Alloy wheels, and holes look ok.
Thanks |
2nd Aug 2018 4:01pm |
[quote="ian series 1"]Swivel bearings, check the preload on either side,
Easy job ????????? |
2nd Aug 2018 4:02pm |
Click image to enlarge |
2nd Aug 2018 4:56pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16901 |
What kind of tyres do you have?
2nd Aug 2018 5:11pm |
Mud terrain
6th Aug 2018 2:22pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Mud terrains are notorious for wobbling.
6th Aug 2018 4:24pm |
Have a look to see if the outer tread blocks are worn unevenly, since this tends to happen on mud terrains that are used principally on the road, especially at higher speeds. You will probably find that alternate blocks are more worn.
This is a well-known phenomenon and there is little that can be done about it. |
6th Aug 2018 8:16pm |
Thanks.
However it only just started after the issue with the wheel nuts. There was no wobble before and seems to be linked to the wheel nuts being loose? Thanks for the help though. Tank |
7th Aug 2018 9:48am |
600 miles with loose wheels would be enough to cause peculiar tyre wear. Have you tried swapping front and rear over to see if that makes a difference? It would at least tell you if the problem is with the wheels and tyres or with the axle.
7th Aug 2018 11:34am |
Clever idea Blackwolf.
Inspected them last night and they look fine, no uneven wear etc? |
8th Aug 2018 2:57pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
it's an easy one so as a matter of course I'd swap front / back diagonally.
panard rod bushes? |
8th Aug 2018 3:02pm |
