![]() | Home > Puma (Tdci) > Theft/Immobiliser alarm movement detecter disable for pets |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
or if you're a little shorter by your right ear
![]() have a great time. ![]() |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1068 ![]() ![]() ![]() |
Bear in mind that it's not just the motion sensor you have to worry about. The anti-tow stuff will be triggered if the alarm is on, but the vehicle moving. Not sure how your dog will react to that.
When travelling to Orkney on the ferry, I just sit in the cold with the dogs on my lap, but as I suffer badly from seasick, I'd be sitting outside anyway. |
What anti-tow stuff? Darren
It does have tilt/nudge alarm doesn't it? I know my 2015's alarm goes off on a ferry if I don't lock with just the key.
No, I'm afraid not. Perimeter and volumetric only on the Defender. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
There is an inertia switch built into the central locking version of the AS10 unit, something I didn't know until this thread came up on the forum, see in particular Fifth Horseman's post about 9 down from the start. Quote from TOPIX:
However it doesn't seem as though the inertia switch actually triggers the alarm, it just unlocks the doors and flashes the hazards, and so is unlikely to be setting the alarm off on a ferry. That, I would think, is more likely to be the perimetric or volumetric alarm being activated, perhaps by a loose connection (it would be interesting to read the AS10 data see what it thinks is the reason for the activation). |
Correct, the AS10 inertia switch is as far as I know only present on central locking vehicles which have a mechanical fuel pump and no electric pump, which is the 2.4 TDCi.
The TD5 and 2,2TDCi with electric pumps have to have an external inertia switch since the AS10 cannot turn off the fuel pump (which is I believe a legal and type approval requirement). I don't know if those with an external inertia switch and central locking also have the handy "bump the vehicle to unlock it" theft feature, but I imagine that they do. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7939 ![]() ![]() ![]() |
I think I may have made a little bit of a boob. I had the drivers lock removed as a minimal theft deterrent, but hadn't thought about locking on a ferry/when using a roof tent. Can I just manually lock via the rear door?
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
No, it's the drivers door actuator that switches the system on and off. Darren
Thank you! Oh poop
sloderby1 Member Since: 08 Feb 2018 Location: Derby Posts: 20 ![]() |
I think you're referring to the crash sensing inertia switch, TD5 & 2.2TDCi have these as they have electric low pressure fuel pump, 2.4TDCi does not have said pump so also does not have the fuel cutoff inertia switch. This is bolted to the top of the bulkhead behind the engine & wires into the engine management. The 10AS has it's own internal inertia switch for releasing the locks in event of impact. |
