Home > Puma (Tdci) > Headlight Beam Adaptors/Deflectors......for France
johnnyd
Hello again
Got some Eurolites beam adaptors but the defender is not covered as a vehicle in the instructions, so its a generic 'Line Patterned Headlights' fit......does anyone have any photos of how/where they should be applied? I cant find anything on a google search....
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #721385 4th Aug 2018 11:02am
zsd-puma
From a google search. That's a Morgan, but same head lamps.
Post #721388 4th Aug 2018 11:22am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Lo-tech sticky tape for me... facing the front of the vehicle the triangularish shape on the left of the lenses is self-evident, just cut to shape.
Someone will point out the possibility of the adhesive damaging the lenses, it ain't never happened to any Land Rover I've ever owned, or any Morgans which use the same 7" headlights.
Peter
Edited to add: picture just posted shows the more expensive version of my sticky tape!
Post #721389 4th Aug 2018 11:23am
johnnyd
Thats more or less what I had assumed also, but what is vague is where to cut either side, the instructions imply line up the outer edge of the circle with the outer edge of the headlamp and trim the narrow end, but in that pic you posted, it seems to be trimmed at both ends, what has he used as a reference to do that?
Post #721391 4th Aug 2018 11:25am
Bluest
Just fill in the triangular bit with tape as per above. In my experience the Eurolights arenot that precise due to their generic nature, you’ll probably do a better job just following the lines on the glass.
There should be no worries about damage in a glass lens, but my plastic lens crystals lights were ruined by electrical tape last year. On removing the tape the adhesive had somehow eaten into the plastic and caused it to craze. 2007 110 TDCi Station Wagon XS
Post #721393 4th Aug 2018 11:35am
zsd-puma
exactly, it's just the triangular part of the lens you need to cover, how you do it isn't important.
Whether you chop one end or both ends off the sticker, doesn't really matter so long as the triangular section in the lens is covered. On Defenders and all traditional 7" headlamps tape works just as well. Eurolights only really make sense on more modern headlamps.
Post #721400 4th Aug 2018 12:00pm
johnnyd
Thanks for the explanations guys......now I know what is actually necessary, its a lot easier Smile Might even use tape LoL
Post #721441 4th Aug 2018 4:23pm
Bluest
Tape is cooler. Makes you look like a Continental driving pro! 2007 110 TDCi Station Wagon XS
Post #721455 4th Aug 2018 6:08pm
Gilloverland
cheap enough to just buy a pair of lhd headlamps ...
Post #721464 4th Aug 2018 7:21pm
zsd-puma
This is true and you'll get better light output than you will with tape on them. However you'll still need to tape them for your UK bit of the trip if it's at night. Because LHD ones dip right not left.
Changing headlamp units is a bit much for a day trip though. Laughing
Post #721503 4th Aug 2018 11:36pm
