Home > Td5 > Weird knocking noise.
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
Hello all.
Defender 02 TD5, just noticed a knocking noise coming from the n/s of the engine. Can't pin point the location but it doesn't
speed up with revs, depressing clutch peddle, and so on. Just ticks/knocks away like a clock. What on that side of the engine could knock that isn't effected by revs? this is all when the vehicle is parked.
Any ideas would be welcome.
Thanks Winter's here, thanks goodness!
Post #720940 2nd Aug 2018 5:45am
Does it happen parked up? QRZ 2e0vpf
Post #720941 2nd Aug 2018 6:23am
Chamois
Hi
yeah does it parked. Winter's here, thanks goodness!
Post #720945 2nd Aug 2018 6:54am
does it make a difference whether the aircon is on or off ? aircon clutch ?
Post #720976 2nd Aug 2018 10:13am
dorsetsmith
remove drive belt check all pultey baring
Post #720985 2nd Aug 2018 11:18am
Chamois
No air con on this one.
Will have a look at all the Pully bearings tomorrow.
Post #721000 2nd Aug 2018 11:56am
Chamois
Checked pully's and all seem fine apart from the water pump which seems to have a bit of play when you rotate it? Is that normal? Winter's here, thanks goodness!
Post #721166 3rd Aug 2018 6:32am
mk1collector
Check the power steering pipe is tight into the pump. Ray
My build thread
Post #721505 5th Aug 2018 12:38am
Chamois
Hi, will have a look tomorrow. Thanks! Winter's here, thanks goodness!
Post #721889 7th Aug 2018 7:40am
