Home > Puma (Tdci) > 2.4 Tdci Fumes from oil filler.
mobilesawmiller
Just noticed after a bit of a run that there are fumes coming out of the oil filler on my 2007 2.4 Tdci. It is driving well and not consuming oil. Any ideas?
Post #720867 1st Aug 2018 5:47pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
It would probably be injector seals blowing a bit,
Have you ever changed them? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #720870 1st Aug 2018 6:32pm
Mdm
as above new seals asap before it does damage.
lots of threads on it.
Post #720911 1st Aug 2018 9:03pm
ian series 1
I started doing some at work this afternoon, I had a 2010 90 come in with the injector clamp loose on 3-4,
They had driven it a good 20 miles to get back home!
It’s the first one I’ve seen where the injector tip has swollen due to the ecu over fuelling that cylinder, this then causes the tip to overheat.
This is also a problem if you run water in the fuel, it can go through the injector and “hydraulic” in the tip,
I’ve got a new injector coming in the morning, as you can’t fit the copper washer over the end,
It was cheaper to fit a new one, than get it repaired.
£159 for a new Denso one.
Change your copper washers, O rings, and get some new clamp bolts,
Look at the rocker seals to see if you have oil sitting around the injectors, if so replace those as well.
A slightly swollen tip! Whistle
Well hammered copper washers! Rolling Eyes
 80" 80" 86" 88" 90"
Post #720920 1st Aug 2018 10:18pm
zsd-puma
And you cant really get them repaired. No one in the UK is fully equipped to test or rebuild them. Some can fit new tips, but they still don't have the correct tools to do more than a basic function test - ie they can only pump fuel through them and see if it sprays out. Not test the correct amount of fuel is dispensed etc.
Unlike Bosch and Delphi injectors have plenty of people able to refurbish them.
Are the Copper washers still insanely priced from Land Rover? Just under £20 each?!
You can get them for about £1 each from most injection specialists or about £7 each from Citroen dealers and £8 each from Ford dealers.
Post #720937 2nd Aug 2018 12:42am
zsd-puma
Re: 2.4 Tdci Fumes from oil filler.
They do drive surprisingly well even with loose injectors, you only notice how bad they were once they're fixed.
However I would start with the basics, when you say fumes from the filler, is that with the cap fitted? ie is the oil filler cap sealing properly?
Post #720938 2nd Aug 2018 12:45am
ian series 1
Quote
You need to start using these guys.... Whistle
http://powerdrivediesels.com/
The washers come in at £9 each to us,
Green leak off O rings are a staggering £2 each.... Rolling with laughter 80" 80" 86" 88" 90"
Post #720946 2nd Aug 2018 7:12am
mobilesawmiller
Thanks for the help lads. The injector seals and washers were changed recently.
Post #721732 6th Aug 2018 3:06pm
Caterham
is it simply the oil filler seal has gone hard with time and letting oil pass?
Post #721735 6th Aug 2018 3:22pm
