Home > Maintenance & Modifications > 110 Double Cab tailgate mods.
All Terrain
United Kingdom 2004 Defender 110 Td5 XS DCPU Java Black
Hi All,
New here and looking at buying a 110 DC but have some tail gate questions. Is it possible to convert the tailgate to a side opening as opposed to the drop down? Would this be done with just regular SW rear door hinges?
Any suggestions then on mounting the spare wheel onto the rear door? Would a Swingaway be the best option? Also reading the other thread on wheel carriers does the rear door on an ifor Williams foul the tyre even with the carrier open?
Look forward to hearing your replies.
Cheers,
AT
Post #72083 22nd May 2011 9:40am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I have done this mod and used the bottom 2 hinges from a CSW door.
I wouldn't want to hang the wheel off it, I already had a swingaway carrier so I kept that.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2002 Defender 110 DC
Post #72095 22nd May 2011 10:44am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Has anyone done this with a 130? 130 crew cab
98 V8 Disco
Post #72137 22nd May 2011 4:25pm
All Terrain
Looks good!
How did you latch the non hinged side? With the original drop down catch?
Thanks for the info!
David.
Post #72187 22nd May 2011 9:41pm
ben_j85jty
Yep,
Just used the standard latch, it was easier and it's how the rear wheel carrier closes as well so it works on both counts.
I removed the bottom hinges, and the tailgate closure "ring" from the side the hinges were going on. The exposed tailgate was not painted so if your looking for a really tidy finish count on respraying the tailgate. I touched up the areas an I am happy enough with that.
HTH
Ben 2002 Defender 110 DC
Post #72207 22nd May 2011 11:14pm
All Terrain
Thanks for the info Ben. Very helpful.
Cheers,
David
Post #72247 23rd May 2011 11:06am
I have a IW top with a Sonic wheel carrier, and I had to make an alteration to allow the rear flap to clear the wheel with the carrier in the open position. It is however a simple, reversible mod.
I suspect that most swingaway-type carriers may have the same problem, especially if the wheels are a little larger than standard. When I bought my carrier there were very few carriers available that could be used with a tailgate as opposed to a rear door.
Post #72257 23rd May 2011 12:45pm
All Terrain
Blackwolf, useful info too, thank you.
I see you are local as well!
Cheers,
David.
Post #72264 23rd May 2011 2:02pm
bob neville
AT
Just looking at this months LRO and the white 11 reg defender 90 in the Exmoor Trim advert has a side opening tailgate - using 3 hinges. Looks good.
Here is a link to the picture on their site
http://www.exmoortrim.co.uk/index.php/cata...l?sef=hcfp
Bob
Post #72482 24th May 2011 1:41pm
All Terrain
Cheers Bob, that does look good. Funnily enough I have that issue of the mag and it passed me by! Embarassed
Hinges have arrived today, swing away has arrived too, just need bolts and the actual vehicle which I pick up on Tuesday.
Will post some pics once the conversion is done.
Thanks again!
David.
Post #72904 26th May 2011 3:05pm
bob neville
David
Pic's etc will be good, this is a mod I am considering.
Bob
Post #72938 26th May 2011 6:57pm
All Terrain
Ok Bob sounds good. Will post asap.
Cheers!
Post #72999 27th May 2011 12:17am
All Terrain
Picked up my 110 DC yesterday and I have already amassed the necessary stuff for the conversion.
Ben, just wondered if you had any tips for getting the holes aligned correctly for drilling as i assume there is little or no adjustment once drilled?
Cheers,
David
Post #73750 1st Jun 2011 3:51pm
ben_j85jty
I fitted the hinges with all the tailgate mechanism still in place, that way the hinges close it to the original position.
I also looked at the positions of the holes on a regular CSW and tried to fit it the same. 2002 Defender 110 DC
Post #74043 3rd Jun 2011 7:54pm
All Terrain
Cool, that's what i figured but thanks for the confirmation. Thumbs Up
Post #74057 3rd Jun 2011 8:59pm
