Home > Puma (Tdci) > Magnetised sump plug
WeiB.beer
United Kingdom 2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
I have recently contacted motorsports-developments https://shop.motorsport-developments.co.uk...s-43-c.asp to see if they stocked a magnetised sump plug to suit my 2.2 Tdci.
They have responded “Unfortunately we do not have a size listed for your vehicle as we only list my size rather than vehicle fitment, however if you could find out what size it is you require i can check to see if it is an item we stock.”
Does anyone know what the size/description would be for our sump plug (other than the part number of 1013938) 2015 110 Defender Heritage Utility Station Wagon
2014 B8 Audi RS4
2003 Audi A2 1.4 Tdi
Post #720491 30th Jul 2018 5:35pm
MartinK
Do you know if the 2.2 and 2.4 have the same size?
Answer may be on this thread http://www.defender2.net/forum/topic52187.html?highlight=femco Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #720496 30th Jul 2018 5:49pm
WeiB.beer
Great, thank you, part way through the thread dgardel confirms the Puma needs an M14x1.5
I’d seen 14mm elsewhere but not the 1.5 before. 2015 110 Defender Heritage Utility Station Wagon
2014 B8 Audi RS4
Post #720499 30th Jul 2018 5:55pm
WeiB.beer
Look like I’ll be ordering this... https://shop.motorsport-developments.co.uk...1789-p.asp 2015 110 Defender Heritage Utility Station Wagon
2014 B8 Audi RS4
Post #720507 30th Jul 2018 6:51pm
*EDITED* ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #720511 30th Jul 2018 7:04pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I just made my own with a 5x20mm Neodymium bar magnet, drilled a 5mm hole in the centre of the standard plug to about 8mm deep and stuck one of these in, I put a drop of superglue in the hole but it didn't really need it.
https://www.ebay.co.uk/itm/N35-Strong-Roun...r_lnC3u2bA
Post #720515 30th Jul 2018 7:29pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
just for the record m14x1.5 pitch is a metric fine thread. not standard m14 110 xs s/wagon
s3 swb soft top
Post #720520 30th Jul 2018 7:39pm
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
These'll do the job - xcess 4x4
Post #720536 30th Jul 2018 8:32pm
WeiB.beer
Bow down Thanks for this link. Perfect!! If I had know about this supplier sooner I would have purchased their 5 plug kit "This is a Kit designed for the 'Angry Pumas' Group on Facebook. This Kit gives you 5 x of our SMPs, all for Pumas. 1 x For Engine Sump, 2 x for gearbox, replacing the daft Torx blanking Plugs with 2 x of our SMP ones with a Socket head (Hurrah) and 2 x of our SMP units for the axle drains." 2015 110 Defender Heritage Utility Station Wagon
2014 B8 Audi RS4
Post #720607 31st Jul 2018 8:47am
MartinK
Great find smb, I will have some of the drain plugs for the gbox, transfer box, and axles... Thumbs Up
Not the engine tho - I like the FEMCO Wink
I would have though the engine would have been ok (as it has the filter) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #720610 31st Jul 2018 9:03am
