![]() | Home > Puma (Tdci) > Headlight flash |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Probably the switch toasted
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
Maybe i'll pull it apart and have a look, it works forward just not back!
No one else have any ideas before I pull it apart?
As suggested, it's likely the switch - that's the horn/main beam/indicator stalk. Darren
Bridge the switch carefully. If it works it’ll be the culprit and buy a new one.
If not the issue is elsewhere _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I bought a new one incase the old one was toast but on inspection
I didn't realise these were still so basic! A 30 second fix! I now don't need the new one! |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
Unfortunately the stalk still has all the headlamp current running through it so it's only a mater of time before it fails.
More so if you swap between main and dipped lamps at night. This is why I fitted a good quality aftermarket relay/loom up grade kit. Cheers, Kyle. |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Landreiziger loom time too I'd suggest. Shouldn't have another stalk pop again, with the added benefit of brighter lights! (If you're using halogen of course)
Thinking about it, I presume you are using halogens, as LEDs should ever pull enough juice to pop the stalk.. ![]() What was the fix you did to get it working? |
It hasn’t gone pop! As I said in the earlier post a 30 second fix! It was just a build up of fluff between the contacts! A quick blast with the air line and fixed! And yes, I’m running speaker led’s.
Ah apologies! I misunderstood. I assumed you meant you'd freed up the contacts that usually weld themselves shut or something!
Yeah those LEDs should be pulling enough current to really bother the switch. ![]() |
