Home > Td5 > gaskets required for a transfer case swap
excossack
Soon to be having the transfer case swapped on the 110 for a freshly built one. Are there any gaskets required for the job? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #719668 25th Jul 2018 4:20pm
Devon-Rover
Nope no gaskets on the T-box to G-box join. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #719684 25th Jul 2018 5:29pm
None, just a bead of silicone around the joint. well around the shaft....
be careful you don't damage the oil seal as the t/box is offered up into position.... hence why the sealant around the shaft Whistle
Post #719685 25th Jul 2018 5:36pm
excossack
Cheers all. 1999 Defender TD5 110
Regards
John M0VAZ
Post #719686 25th Jul 2018 6:21pm
