![]() | Home > Puma (Tdci) > Ravenol Brand? |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
It's a German company.
https://www.ravenol.de/en/company/history.html It's one of the smaller lubricant manufacturers like Millers or Comma in the UK, small compared to Castrol (BP) or Exxon-Mobil. It is available in the UK, but oil is more readily available from the UK based manufacturers, which is probably why you don't here so much about it. I expect it's good stuff, just I'd have to make an effort to buy it. |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
sorry going well off topic here
how is it you appear to have a puma and live in the states? I didn't think the two were possible? sorry curiosity got the better of me |
| MGRGPGBG Member Since: 19 Dec 2017 Location: New York Posts: 70
I bought it used with tranny from a guy on the west coast. Honestly not sure how he got it. Removed from a 130 that he was doing an LS engine swap to. Have been seeing more and more 2.4 and 2.2 engines here in the USA. These are not coming over complete in PUMA version trucks, just as engines I believe.
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Curious too
Can you speak to a USA JLR dealer to get the spec? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
They seem not to be too up to date on the specs since they haven't sold defenders here in years. Ford service department has been helpful and has the transmission fluid in stock.
I have the specs from the manuals, but since diesels and manual transmissions are a minority here it seems that the major brands do not stock the same items in the US. |
I would have thought the engine oil should be easy to find. It's nothing really 'special', it's used in most modern diesels I think. I expect the Ford V8 diesels used in pick up trucks would use a compatible oil.
The 2.4 is less fussy than the 2.2 because it doesn't have a DPF. |
But how do you have/run a Puma in the USA?? James
answered that above already
Sorry I missed that before my first comment
| All times are GMT |
