Home > Technical > question re: upgraded Ashcroft HD halfshafts
Page 3 of 5 <12345>
Yes, that’s true. They are tapered too I believe so should be fine. Just sticking to standard drain plugs nothing else going on.
The flanges arrived today, top notch service next day delivery! I only bought them lunchtime yesterday.
I only need now an 8mm hex socket (male) to fit, I can at least get the front fitted. The rear needs halfshafts and flanges. So yet to get the shafts. Hopefully in a few weeks or something.
Because everyone likes pics here, I thought I’d add up some:
 ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #718758 20th Jul 2018 3:16pm
jst
when you do fit my advice is to lightly lubricate the cao mating surface around the o ring area and to grease the gasket both sides. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #718849 21st Jul 2018 5:40am
Thank-you for the advice, much appreciate that. Thumbs Up
I was thinking of using Lithium grease for the splined end of the halfshafts to flange. The same grease as I used for the prop shaft UJ's this one: https://www.ebay.co.uk/itm/Castrol-400G-Hi...2749.l2649
I know the area you mean on the caps of the flanges, the threads and mating surfaces between the two in the O ring area.
Wouldn't a little copper grease be best for this one as it's anti seize based?
The gasket sides is a good idea, Lithium should be fine for that as it's just for a better seal isn't it's only a thin smear.
Just waiting on a few bits and pieces to do the front, the rear will have to wait just for a bit until I can get the due to cost.
I would imagine the halfshafts should be fully axle oil lubricated before going in too.
Having never done it before advice is always welcome regardless of how easy or simple the job is. Very Happy ____\We|Will|Win/___
Post #718885 21st Jul 2018 11:22am
jst
Don't fit Ashcroft axle to shaft oil seal, this allows some axle oil to lubricate splines and it wont come out the end with their dm caps.
Copperslip, or any grease gun grease on dm cap and o ring.
Vaseline also works well on gaskets, just rub it all over both sides, wipe away surplus. Means gasket will come off easily if taken apart again, plus you can prob then reuse gasket. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #718892 21st Jul 2018 12:20pm
Thumbs Up I did read the info regarding the axle to shaft seal on the rear.
I notice they mentioned the rear but not the front, is there a reason for this?
I've got a hex bit set coming and oil drain pan suitable. (Needed anyway.)
I just need it find out what axle oil D44 used on the rear to change the front as it could do with doing and replacing anyway really.
Think it's Fuchs 75/90w but may as well find out the exact type.
Once I've got the oil, I can then try and get the front done at least and the rear will have to wait a bit until I can sort out buying th shafts. Seeing as both need replacing on the back both the shafts and the flanges there's is little to save.
Hopefully not too long though.
I'm curious as to the spline lubrication debate between oil seal removal and greasing instead.
I was intending to do the latter as I can see little difference in it, especially if only the rear is oil lubricated and the front greased.
I was told the flanges and splines were very dry, so it seems like some 'fretting' had gone on.
Here was me assuming servicing took care of that! Unless some water got in.
This is on top of the Pro UJ issues I had, so can only but imagine the various issues went hand in hand and started going together.
As Blackwolf mentions it seems, when all is well with the Puma driveline it is but can be fairly fragile if issues develop.
I also can't understand why the rear diff pinion oil seal keeps going, it has done so there or four times over the last few years.
Again, always the rear drive axle and no issues at the front. ____\We|Will|Win/___
Post #718958 21st Jul 2018 5:39pm
I cracked on with this tonight, I got one done on the front but got beaten to carrying on by it getting dark so will need to be tomorrow to finish the other side.
Took it very easy undoing the bolts, slow and square on and they were fine.
I used a 1/2" ratchet to 3/8" reducer with a I think it was a 3/8" 17mm socket
New bolts went in a dream with the spring washers to 65NM.
Again using my 1/2" torque wrench as above but with 3/8" to 8mm hex drive bit
Greased the splines and on the flange inc both sides of the gasket.
There is much less play there now, far less.
There was indeed some 'fretting' rusty rubbish etc and I fully cleaned it all as best I can before fitting everything.
The fit is absolutely excellent!
Only thing I found was when removing there was a thick and thin shim, the thicker one tapered and the thinner one not so.
When fitting I could only get the single thick tapered shim (correct way around of course.) to fit and the circlip.
With the thinner shim as well the circlip would not go on and this was with the shaft pulled as tightly though as possible.
With the thick shim and the circlip though is a perfect fit and a tight fit so as far as im concerned it's a good fit.
Also greased the cap threads and O ring, I can indeed see the beneifit of fitting a grease nipple to the cap but that's a job for another day.
The original flanges and splines were pretty much dry, but okay on the shaft splines but flange very worn.
When it comes to the rear when I change the halfshafts as well, will they just come out with the flange removed or is there other things to remove?
Having never done it before it's all new to me, but this was a pleasure of a job to do so far.
Thumbs Up
One last thing, I haven't this time due to not having a huge amount of grease to spare so I don't run out.
(I've got enough to do the splines properly though.)
But shall I pretty much pack the whole cap with grease? I'd have thought that should stop moisture condensation etc setting in there.
At least that's an easy job to go back to, now the splines are thoroughly greased with the Castrol HT Lithium. ____\We|Will|Win/___
Post #720020 27th Jul 2018 8:59pm
Forgot to add a pic I took,
as you can see they needed doing: ____\We|Will|Win/___
Post #720024 27th Jul 2018 9:32pm
At the rear you can just pull out the flange complete with halfshaft.
Post #720027 27th Jul 2018 9:44pm
Oh good, just the front has more components then. Thumbs Up (Thank-you.)
I must say it's a much nicer job than replacing the UJ's!
Very nice quality and fit with the Ashcroft units, hopefully buy the halfshafts in a couple of weeks.
They must be much better for keeping the crud out too. ____\We|Will|Win/___
Post #720030 27th Jul 2018 10:23pm
Finished the front axle today, I may change the oil later but no rush.
I'm pretty sure the axle drain + filler plug are a compression seal, they don't need any sealing agent do they?
If so, I better leave alone until I get some.
(I can't seem to find any WSM infor on it for some reason!)
All done:
Post #720101 28th Jul 2018 4:52pm
Axle drain (and filler) plugs are tapered thread. If you buy new ones, they do tend to come with a sealing agent embedded in the threads. If re-using existing, then a bit of PTFE tape is a good substitute.
I tend to replace mine with magnetic ones, which is a very cheap little mod:
 Darren
Post #720121 28th Jul 2018 7:50pm
They're a BSPT thread, full form, and seal on the threads. They shouldn't need any help sealing and I've never used any on mine. However a few turns of PTFE won't do any harm.
Post #720126 28th Jul 2018 8:14pm
Excellent, have a little PTFE tape hanging around anyway.
Goes to show how useful it is to be prepared, may or may not use the PTFE tape yet I've not made my mind up. Thumbs Up
Probably think about a mag one possibly one day. Thumbs Up ____\We|Will|Win/___
Post #720138 28th Jul 2018 10:16pm
Also, I didn't do the oil today the weather was a bit windy! I know I don't need to do it but I may as well as the rear was replaced a couple of weeks ago.
Went out tonight and the drive is much improved just with the front flanges done.
When the rear halfshafts and flanges are done as well it should be perfect. (Hopefully soon.)
Surprising how wear and tear like this creeps up and you hardly realise it over a period of time until you completely replace parts. ____\We|Will|Win/___
Post #720140 28th Jul 2018 10:32pm
Caterham
I fitted these the other night - no spacers fitted and svx wheels fitted no problem Thumbs Up
Post #720154 29th Jul 2018 8:04am
Page 3 of 5 <12345>
