![]() | Home > For Sale & Wanted > [Wanted] Steering guard and 4 point roll cage wanted |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8442 ![]() ![]() ![]() |
i have a QT internal cage that used to be in the my soft top, 4 mount (so hoop and rear stays) it doesnt support the soft top though which you might be after? but as after a 4 point not 6 maybe not? not sure. Cheers
Phid Member Since: 25 May 2018 Location: Dorset Posts: 85 ![]() ![]() |
I’m definitely only after a 4 point cage - do you have any pictures please?
I have rear seats so need the rear stays to mount to the sides (like the SD cage) and not the floor. Is it bolt it? Thanks |
It's a proper 4 point. Sounds like you are after a hoop with tub stays then. Cheers
Yes you are right - I’m using the wrong terminology
Thanks anyway |
