Home > Puma (Tdci) > front axle swap
millepet
Belgium 2009 Defender 110 Puma 2.4 SW Orkney Grey
front axle swap
Will a 90's front axle fit a MY2009 defender 110? Are 90 and 110 front axles identical?
Post #718111 16th Jul 2018 9:45pm
zsd-puma
90's don't have vented discs for a start, so you'd have to swap those for the 110 vented ones.
I think the differential is different on the 90.
But the axle casings are the same I think.
Post #718140 16th Jul 2018 11:48pm
millepet
It is the casing I need. Mine is bend after an accident. I can swap all the internals and bolt my swivels to the older casing.
Post #718144 17th Jul 2018 6:11am
Retroanaconda
As long as it’s of a similar age then it will fit. 2002-onwards should be okay.
Post #718153 17th Jul 2018 7:01am
millepet
I found out bushes are 40 mm, an anti roll bar fixings fitted standard from 2002.
Post #718227 17th Jul 2018 4:10pm
LR90XS2011
my 90 has vented discs, the diffs are different 110 has a stronger diff DEFENDER 90 TDCI XS,
Post #718276 17th Jul 2018 9:07pm
110s post 2010 supposedly have the stronger 4-gear diff, but many don't. The diffs are interchangeable however.
Post #718288 17th Jul 2018 10:20pm
dgardel
Italy
LR90XS2011 wrote:
my 90 has vented discs, ....
Mine too from the origin.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #718325 18th Jul 2018 9:53am
millepet
It is frightening when someone turns over when you pass cars at 90 km/h,
Post #718328 18th Jul 2018 10:07am
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
From 1994 onwards the defender and discovery 1 front axle had wide radius arm bushes fitted.
Therefore any 1994 onwards 90, 110 or disco 1 axle will fit your 110 (providing ARB mounts are present).
Depending on what year axle you buy you may need to swap the brake assembly from your original. Everything else will be the same. The '4 pin' diff was only fitted to the rear of a 110 from 2002 onwards, all defenders were fitted up front with a 2 pin.
Post #718333 18th Jul 2018 10:18am
TDCi Defenders with nominal 110 and 130 inch wheelbases were "upgraded" to a four-gear front diff as standard ostensibly from 2010, according to Landrover's build spec.
The experience of certain forum members however has made if very apparent that whilst some or even many left the factory with the four-gear Rover pattern diff, a significant number were still built with the 2 gear diff. It seems to be utter pot luck whether you have a 2 or 4 gear unit.
TDCi Defenders with the nominal 90 inch wheelbase always had 2 gear diffs, none were built with 4.
Another consideration if you are swapping axle casings around is to try to avoid the batch which has defective welds holding the end flanges onto the casing, and for which the reinforcing bits were retro-fitted on TSB.
Post #718356 18th Jul 2018 1:16pm
Retroanaconda
It needs to be 2002-onwards as the bolts for the panhard rod changed size, as well as the rod itself changing from a solid forged rod with a bend in it to a straight one formed of hollow tube. The bracket welded to the axle casing is suitably larger to match, though you could in theory drill out the hole in an earlier one. The bolt size went up from M14 to M16.
Post #718372 18th Jul 2018 4:00pm
millepet
Thanks so far. My chassis has a dent, so it could be I have to change the chassis for a new galvanised one. Is there a favorite constructor?
Post #718400 18th Jul 2018 6:13pm
Retroanaconda
Assuming the main chassis rail is undamaged and not bent/misaligned, you can buy weld-on replacements for the radius arm brackets. For example:
https://yrmit.co.uk/product/rhs-front-radi...t-stc8604/
Post #718504 19th Jul 2018 8:16am
millepet
there is a dent in the main chassis rail, just in front of the radius arm bracket. Bulhead moved to the rear, bracket from the torsion bar ripped out of the chassis, front axle bent...I should have to take off the body to mesure up the chassis, but I fear the worst.
Post #718729 20th Jul 2018 1:19pm
