Home > Maintenance & Modifications > Fuel filter bolts changed - recommended!
UtilityTruck
When undersealing the truck recently I had the steel fuel filter cover off and noticed the bolts holding the filter assembly to the chassis were in a terrible state.
Changed them today along with new washers. The rustier of the two was the forward fixing. The bolts are proper zinc protected automotive fasteners and the truck is only 4yrs old.
I think another few years and getting one or both of them out could have been a struggle.
Fuel Filter bolts p/n FB108206
M8 Washer p/n WC108056
Bolts are about £3 and the washers £1
 2014 Keswick Utility 2.2
Post #717538 13th Jul 2018 7:31pm
williamthedog
Done mine a few months back. 2011 build looked like they were recovered from the Titanic.
Replaced mine with stainless bolts and plenty of anti corrosion paste applied. Especially cover the front bolt it gets all the spray and muck. Thumbs Up
Post #717544 13th Jul 2018 8:28pm
UtilityTruck
I don’t think it helps that the holes are slotted so there is space for cruddy water to sit in there and rust up the bolts. 2014 Keswick Utility 2.2
Post #717562 13th Jul 2018 9:27pm
williamthedog
Yep you're right there. I fitted bigger washers in a attempt to try and stop this. Time will tell. Thumbs Up
Post #717564 13th Jul 2018 9:33pm
Vitesse
Good advice.....I checked mine which are three years old and were slightly corroded. Covered them in copper grease.... will order replacements though Thumbs Up 2015 90 XS Santorini Black
Post #718216 17th Jul 2018 2:10pm
Wow, over £3 each for an M8x100mm bolt. Shocked
You can get A2 stainless for less than £1 each.
Post #718246 17th Jul 2018 6:20pm
I haven't changed mine, but I did clean up and well Dinitrolled them.
Never had an issue this way, if I was to change I'd go stainless in this situation as they are nothing load bearing in any way.
With some anti corrosion block they'd be fine. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #718267 17th Jul 2018 7:49pm
