Home > Td5 > Diagnosis Please
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Diagnosis Please
(and help with spelling!)
A few days ago our 2000 td5 refused to turn over.
Charged the battery and next day it was fine
Day after - no turning over.
Bad battery thinks I so changes it
Ok for a couple of days then stops in the middle of a run same symptoms.
After leaving it for an hour it starts and runs
Looking at the battery the +ve terminal is very hot
Volts look good
Charging seems to be 20A ish
Are we looking at an alternator gone US?
cheers for the help as always
CC
Post #717894 15th Jul 2018 8:01pm
chopcat
Having read up a bit now I am thinking it is the starter motor.
Difficulty turning the starter over
sticky so when it is running it is acting like a generator and super charging the battery making the terminals hot and frying the old battery.
Will tell you if a new starter sorts it out.
unless anyone has a better idea.
Post #717898 15th Jul 2018 8:27pm
dorsetsmith
or repair it
Post #717900 15th Jul 2018 8:32pm
roel
If your startermotor is turning very heavy by hand. Open the gearbox section and change the grease. Roel
2003 90 Td5 (2009-now)
Post #717914 15th Jul 2018 9:12pm
chopcat
With the starter changed the symptoms seem to have dissapeared.
I put a new one in for £90 to get it done quickly. So fingers crossed it will remain that way.
Interestingly not many here seem to have had the same problem so hopefully this might be useful to some.
Tc
Post #719196 23rd Jul 2018 6:58am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I don't know the correct term. But the wiring to my starter played up until I cleaned the switched live and greased it up. Messing and wiggling the connection would get it to start.
It was always after it had got wet or damp. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #719204 23rd Jul 2018 8:30am
