Home > V8 > Can I use ...
Mo Murphy
Can I use ...
Hallo all,
Can I use a Tdi diesel fuel filter to filter the hp side of petrol supply for a 3.9 efi V8 ?
50 Shades of Pennine Grey
Post #717643 14th Jul 2018 12:47pm
Mdm
not recommended
Post #717668 14th Jul 2018 2:56pm
Mo Murphy
Any reason why not MDM ?
Post #717675 14th Jul 2018 3:37pm
Mdm
if memory serves me its down to 2 things .
micron filter numbers are different for petrol to diesel to remove impurities and debris etc.
diesel filters are meant to take water out of the fuel.some have drain plugs for this some don't.
i suspect the internals will be similar or certainly have been on ones we have cut open.
on some of the old army landies we have weighed the new filter full of fuel and the old filter and there is a difference as the used one is always heavier.
is there a reason why you want to use the wrong filter?
Post #717677 14th Jul 2018 3:51pm
Devon-Rover
My 4.2 90 ran a boy racer filter off eBay sytec filter on the inside of the seatbox worked fine with me.
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #717679 14th Jul 2018 4:09pm
V8GPC
https://bearmach.com/fuel-filter-br-0272k
This kit comes with fittings, and is what's used on the Defender 50th 4.0L
Goes between tank engine on HP side; (normally on the chassis.
https://www.roverparts.com/resources/video...fender-90/
Post #717684 14th Jul 2018 5:19pm
Mo Murphy
Thanks chaps 👍
I was just asking because it's there already but as it doesn't seem suitable I'll explore the other avenues suggested.
Many thanks
Post #717726 14th Jul 2018 8:32pm
