Home > Tdi > Wolf 300tdi Donaldson Air Filter
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
Hi All
I have just picked up a Donaldson air filter box as fitted in the 300tdi military Wolfs. The filter is a 2 part inner and outer.
I'm sure I read that in typical UK conditions there is no need to use the inner (safety element) filter, only the outer was needed. The inner is only intended for seriously dusty conditions (eg Afghan/Iraq).
Am I right?
thanks. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #682909 30th Jan 2018 3:30pm
Tommyharris
2013 Defender 90 Puma 2.2 HT Santorini Black
I found if you run both the 90 feels restricted and blacks under acceleration.
I just run the main everday and both when off road or messing in water.
I did struggle to find replacement filters too
Post #717672 14th Jul 2018 3:10pm
foxhound
for info i found a list of donaldson wolf filter part numbers and placed it here: http://www.defender2.net/forum/topic61830.html
scroll half way down or so 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #717673 14th Jul 2018 3:15pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
I run with just the main, the inner filter is only needed in dusty region's
Post #717744 14th Jul 2018 9:52pm
donmacn
Thought I'd add this question onto the bottom here rather than a new thread:
I've just fitted a Donaldson filter box as per this thread.
I've used the standard filter mount bracket, and the bands as specified here and in Foxhound's linked thread.
I did though, use these 'bobbins' too, between the new bands and the existing bracket.
However the new filter box is just a bit too high, and rattles against the bonnet. The obvious answer is to remove the bobbin rubber fixings, but presumably that just transfers the vibration somewhere else that maybe wasn't designed for it? I'm thinking it would specifically make the intake pipes vibrate a lot more.
How have others got round this? I did read about someone using 'quickfist' clamps here -made of rubber so would probably provide some damping.
It's only a marginal thing - certainly 5-10 mm would give enough clearance. I wondered if anyone knew what these mountings might be called so I could google for thinner ones?
TIA Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #813784 5th Feb 2020 8:08pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Hi Donald, from memory (and it was a long time ago) but have a look for exhaust bobbins to suit a classic mini, they were quite thin and I seem to recall they did the trick on something I was mocking up a while back. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #813804 5th Feb 2020 9:18pm
donmacn
Thanks Harry. I'll have a look at those. I also googled something like 'rubber bobbin mounts' and found this:
https://www.polymax.co.uk/anti-vibration-r...bin-mount/
You can search on specific dimensions, so I'll get out and measure the stock LR ones and see what would fit without fouling the bonnet. Donald
in the past..
Post #813822 5th Feb 2020 10:00pm
