Home > Wheels & Tyres > 285 on wolf rims and snow chains
MK
Most likely the topic has been addressed but I cannot find it.
My 285MT are on steel 8 inch ET0 but I kind of not like the look as they stick out too much.
So the proper choice would be to fit 255 on wolfs but such tire size is quite rare here. Last chance would be to fit the current 285 on wolf rims I can get for a cheap price. I do know size wise they should not be paired. My concern is if snow chains would fit with the combo as the rear gap between the tire and spring tower is quite small.
thanks Puma 110" SW
Post #717582 13th Jul 2018 11:23pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
LR Wolf rims are too narrow for 285 tyres, the wolf rim been 6.5" therefore there is a real danger of poping the tyre off the rim and is not recommended.
Post #717627 14th Jul 2018 10:20am
You are very unlikely to be able to run tyre chains on either 285/75 or 255/85 tyres due to insufficient clearance. Unless you have a fairly radical lift or have enlarged the arches you'll do considerable damage.
Post #717748 14th Jul 2018 10:08pm
MK
Thanks for the feedback.
So I figure out that 255/85R16 has never been a LR option for the Defender(?). Puma 110" SW
Post #717844 15th Jul 2018 4:00pm
Grouse
No, but I have seen several Scottish Power Defenders fitted with 255/85/16 from new. Not sure if these were factory fitted by LR SV vehicles or aftermarket. Some of the vehicles in the same fleet also had BFG 265/75/16 on Wolf Rims.
Post #717867 15th Jul 2018 6:09pm
