![]() | Home > Puma (Tdci) > The strip down begins, TDCI head-gasket?? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
![]() Wanted, Forward Control Anything considered. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2474 ![]() ![]() ![]() |
Thanks a lot.
When I was replacing the front crankshaft seal last week I was wondering about the issues you perfectly addressed. ![]() Puma 110" SW ............................................................. Earth first. Other planets later |
CaptainDan Member Since: 14 Apr 2017 Location: Victoria Posts: 53 ![]() ![]() ![]() |
Hi Ian,, please to here that you have the 90 running again, I am at the point where all things have been checked and the next step is to remove the head so this is where it is going to get expensive, again
![]() ![]() ![]() My question is are all Duratec 2.2l equal, are the 2.2's in the Ford transit the exact same as in the Defenders. There is a company here in Oz selling 2.2 & 2.4 Duratec engines for $6k. Just clutching a straws now. Thanks Daniel |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 ![]() ![]() ![]() |
Give these guys a ring.
Quoted me $5.5K plus $1k to fit. http://transitauto.com.au/ I stripped mine today found crack in #4 piston. Funny thing was that it was bringing up #2 cylinder misfire. |
Thanks Harold I will get in touch with them
Daniel |
Hi Daniel
That sounds like it’s an expensive repair ![]() The basic blocks are the same, but it’s always worth a visual check to confirm it’s correct, The sump will have to swapped, but not much else. 2.4 and 2.2 blocks are different, it’s not just bore size, you will find they have different bolt holes cast in the front, And possibly more? Earlier 2.4 duratorqs look similar, but are totally different. I’m supprised at the prices you were given, Short engines are cheap here now, you can pick them up reconditioned for as little as £1000, a few years ago you couldn’t buy one for under £2000. I’m not sure what the exchange rate is, so not sure what that works out to in £s? I hope you have a positive outcome with yours, I would get the head tested and skimmed personally, You may have read, the guy that did mine said the Ford blocks were practically bomb proof, and I have no reason to doubt him. Cheers Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Did you have much water in the oil? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Unnecessary quote removed
I found with my engine that if you rotate it the timing mark on the chain will advance 1 tooth per 4 revolutions of the crank. |
None just misfire and blow by into the crankcase. 106000km |
What are the simptoms of your engine. Mine will loose coolant out of the header tank/ bottle from the cap centing. I have just purchased an Iveco cap that has an external drain hose. I haven't fitted yet but will let you know the results was recommended by someone on AULRO Mark |
I couldn’t get my old chain to line up correctly?
I rotated it so many times I nearly passed out ![]() Like you say, 4 turns on the new one, and it’s back to where it should be. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Hi Ian,
Do you know what the availability of rebuild kits is like over there? Can you recommend any supply centres? Mark |
Hi Mark
Try theses guys..... http://www.lymmengineparts.co.uk/ If you search under Transit, rather than Defender, you will find the rebuild kits. Will post worldwide. ![]() Wanted, Forward Control Anything considered. |
Hi Harold
Some background to my problems are described at http://www.defender2.net/forum/topic62320.html I have not heard back from the guys in Clayton as yet. What would be the purpose of the Iveco cap and drain? wouldn't you still loos the same amount of coolant? What is really frustrating with mine is that it runs fine with no power loss just coolant loss. If it ran like a hairy goat I could understand it be it simply runs fine. Daniel |
