Home > Puma (Tdci) > The strip down begins, TDCI head-gasket??
Page 5 of 8 <12345678>
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Excellent detailed write up Ian, very informative, hope it’s sorted after all the hard work you put in. Thumbs Up
Post #716740 8th Jul 2018 5:11pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Lash up! Rolling with laughter Rolling with laughter Rolling with laughter
Not worked on many modern engine installs then! Very Happy Very Happy Very Happy
Relatively easy compared to say a Subaru... regardless of model. Thumbs Up Thumbs Up Thumbs Up You only have one life, live it....forget the cost.
90XS Hardtop
Post #716750 8th Jul 2018 6:54pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Yes, I’ve worked on a few others...
I was one of a small team of people that helped the Swedish firm Scania, develop their OG9 engined gas bus.
These engines were straight out of the box, very little run/test times had been done at the factory,
Reading busses were being used as a test mule.
We knew very little about the gas engines only that they used an older proven 5cyl 9ltr Diesel block,
The rest was experimental!
We were in direct communication with a team in Sweden, and ADL, who could “talk to the busses”
Through the ECUs and BCUs remotely, we were on the workshop floor dealing with faults as they would arise,
reporting back to them, and they would adjust the ECUs and BCUs as required, changing fuel/ air mix, gas pressures etc,
It was mind boggling as to what you could do regarding making them run!
I worked out of a Scania depot, but was based in Reading busses for months while the engines were being tested,
One major problem being the the shear heat they would generate in city centre conditions,
It was a weekly occurrence that at least 4-5 exhaust valves would burn out, it was recorded that head temps were reaching the same temp as an acetylene flame.
This meant all 5 separate heads came off, and a top end rebuild was carried out to the tune of £10,000 per engine!
New hardened valves were made in Sweden and sent over, valve seats were super hardened to take the higher temps,
The heads alone were £1500 each to replace, I had a van full of the things at one point,
With 20 busses in the fleet, we could of easily done the last few blindfolded!
It’s a pitty I don’t have my old phone, as I had lots of photos of a full engine strip down/top end strip downs,
Which was something to behold.
It would make the Puma engine look like a small truck compressor!
In 2008/9 The first fleet of 15 methane busses we had to convert them back to Diesel, as they were so temperamental,
Running at only 4mpg the plug was pulled, and Scania had to go back to the drawing board.
That was a major campaign, the work involved was incredible!
Have a look here, I’m proud to say I had quite a bit to do with this engine Very Happy
It’s going back a few years now....
https://cbwmagazine.com/first-scania-adl-g...o-reading/
I now work on large and small plant in the Arb industry,
I agree the internal workings of a Puma engine isn’t anything special,
But A majority of the good folk on here will probably never see the internal workings of their motor?
Which is why I started this thread.... Wink
Never liked the Subaru engine, always sounds like it’s got a misfire! Whistle 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #716755 8th Jul 2018 7:48pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Top job mate Thumbs Up Bow down
Stephen.
Post #716787 8th Jul 2018 9:49pm
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Ian I would never have the knowledge, skills or confidence to do that job, But I have enjoyed this thread. Thanks.
Post #716814 9th Jul 2018 1:17am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Top Job Thumbs Up
Don't feel like coming for a holiday to Australia do you?
I just started to remove the engine on my 2012 110 Defender 2.2L Puma.
I suspect it has cracked #2 piston.
There is enough hoses on the RHS to start a rubber factory.
Hopefully will have the engine on the deck tomorrow.
Mark
Post #716836 9th Jul 2018 8:33am
LR90XS2011
Ian
thanks for the write up, hope I never have to do mine, also hope it all carries on working AOK DEFENDER 90 TDCI XS,
Post #716865 9th Jul 2018 11:10am
ian series 1
So, the verdict....
I fitted a genuine Ford chain cover, and another seal tonight, everything fits perfectly,
And more importantly no oil leaks!
I also warned the people selling these covers as O.E.M parts to be careful, as they are not that great at doing a critical job, such as positioning the front crank seal.
All topped up with Coolant again, and time for a road test.
I’m pleased to say after a 30 mile trip, it used no water, temp on the ultra gauge flucuated between 82-93,
Which is just as before.
So whatever I did done the job!
Frustratingly, I couldn’t find anything wrong with any of it??
I had 2 more mechanic friends look at the head gasket, like myself, neither could see any fault with it?
So, i replaced the water pump, which was in GWO, and thermostat, again tested with no issues, tested the egr cooler, had the head tested/skimmed, flushed the whole cooling system through, new cam chain kit, timing chain cover, various gaskets, and oil seals
I couldn’t do much else?
All in all a mystery, but all working lovely again Thumbs Up 80" 80" 86" 88" 90"
Post #717096 10th Jul 2018 9:54pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Great news Ian and thanks again for posting it all here Thumbs Up
It's very frustrating no matter the task when you can't actually find the original problem, but my bet is it was so small you'd need a microscope to spot it.
At least you're all sorted and we're all more educated for your troubles Bow down Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #717138 11th Jul 2018 8:43am
ian series 1
Cheers Thumbs Up 80" 80" 86" 88" 90"
Post #717141 11th Jul 2018 9:05am
mk1collector
Great read, thanks for posting Thumbs Up wish I had your skills. Ray
My build thread
Post #717161 11th Jul 2018 2:25pm
MK
Ian
I assume that using a new original timing cover you did not need to use the centering tool to fit the front crankshaft seal?
As well, how many miles and how were all the timing components such as sliders, tensioners, any stretch on the chain, etc?
thank you
MK Puma 110" SW
Post #717168 11th Jul 2018 3:24pm
ian series 1
Hi MK
There is a trick to seating the seal,
Take the cover and apply the sealant,loosely fit the front cover with 2 bolts at the top,
Don’t tighten them, just let the cover “hang”
Then put the 2 10mm nuts on the bottom of the cover, again just pinch them up so the cover can still move.
Install the seal, then gently tighten the two top and bottom fixings,
Then put all the rest in and tighten up, the seal will find its centre, as they are quite hard seals,
Always done it this way, and never had any issues with leaking seals (except mine! But that was the crappy cover)
When the TDCI came out, you couldn’t get your hands on the special tools, not cheaply anyway, so there was always a workaround! Wink
The timing chain that I took out was an aftermarket one, I’ve no idea how long it’s been fitted for? but only the chain, tensioner guide, and tensioner had been fitted,
The cam sprockets, and pump sprocket were genuine Ford,
As were the other guides.
I brought it with 86,000 miles on the clock, so who or why it was fitted I don’t know?
It’s now on 140,000, apart from very slightly worn cam sprockets there wasn’t much to worry about.
The kits that I fit (at work, and here) include every guide and bolts, tensioner, 2x cam sprockets, 1x pump sprocket, crank/oil pump sprocket, and the chain.
They cost around £200 If your going to do it, replace everything for piece of mind.
Timing pin kits are readily avalible for very little money.
Post #717180 11th Jul 2018 5:46pm
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #717192 11th Jul 2018 7:01pm
Roy5695
Good thread, fantastic workman ship and even better result in the end. Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #717214 11th Jul 2018 8:08pm
