Home > Technical > Indicators and rear wiper not working
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all - I have a problem I'm having trouble diagnosing.
I just had to reconnect a wire in our 12N socket after pulling away from a caravan with it connected -- daft mistake. I noticed that the right indicator on the caravan wasn't lighting up. The left indicator was fine, and I swapped the caravan bulbs to check them, and both bulbs were fine.
After reconnecting the 12N socket I used a multimeter and checked that I had both left and right signals at the socket.
I connected the 12N to 13-pin adapter we have looking to test that, and didn't get a signal. At that point I noticed that the indicators had stopped working.
I'm assuming I have a short or blown fuse somewhere. I have:
- Hazards fine but no indicators
- Fuses 18, 19, 21, 31 all ok
- No rear wiper, but rear spray works
- Something like a relay going clunk .. click .. repeatedly behind the rear door panel with key in II (rear wiper relay? central locking?)
- No rear aux 12V socket power
I haven't:
- Taken the indicator stalk out and replaced
- Taken the hazard light switch out and replaced
Any clues would be very welcome. 2009 110 XS Station Wagon
Post #716732 8th Jul 2018 4:43pm
timbar
So, I could delete this but I'll leave it hanging around in case its useful.
CHECK ALL THE FUSES.
I clearly missed something. I went through all the fuses in turn and the 10A hazards fuse had gone. Replaced it and the indicators are back.
Rear window wiper still an interesting one but it might just need lubricating ... 2009 110 XS Station Wagon
Post #716808 8th Jul 2018 11:46pm
