![]() | Home > Puma (Tdci) > Leaking water front passenger wing right at front |
Washer bottle caps are available on eBay in black or blue
![]() eBay Item No. 292144315072 Ray My build thread http://www.defender2.net/forum/topic17615.html |
Iβd get a torch and see if the pipes are pushed onto the pumps fully and the pumps are fully pushed into the bottle first though. Ray
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
My 2003 leaks when the washer bottle is topped up, so must be out of the cap. Initially I thought it was coolant but traced to the washer bottle, one of the advantages of having blue washer fluid and pink coolant.
Hunky Gibbon01 Member Since: 20 Mar 2017 Location: Dorset Posts: 90 ![]() ![]() ![]() |
Thank you I've bought a cap anyway it's only a couple of quid. And will check the pumps thank you very much for advice.
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 ![]() ![]() ![]() |
Being a tight was I cut up and old bike inner tube and made a gasket for my top and it's not leaked since
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
They have a breather hole in them as well as not sealing that well. When you fill it up to the brim with cold fluid, the fluid warms up and expands so it leaks out. It doesn't really matter though, it's not corrosive or anything and it's usually only a small amount. |
Thanks for that tip ZSD, I must admit I had a "oh no where's that coming from" moment when it first happened!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
As ZSD mentions above.
Mine does it too, and only when topped right up when fluid is sloshed about. There is a tiny little breather right in the middle of the cap too. No problems or issues to worry about if it leaks a bit, it won't do any harm. My washer fluid is apple green. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Have you got air-con....?
Yes i do.
Could it just be the ice melting from the condenser when you stop?
condensation drain is in the middle right above the gearbox.
Aircon does dump fluid, especially in this weather.
We used to have a Navara D40 that used to do it. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
