![]() | Home > Td5 > Hybrid or VNT. Anybody done it? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
I have an IRB supplied VGT on my Td5. make it drive like a "modern" diesel, i.e. much more torque from low revs.
Along with a 190bhp ECU flash as well. |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
Was it remapped previously?
I think I may have had an Allisport 140 or 170 on it. I've got a collection of maps here.
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2228 ![]() ![]() ![]() |
CRTurbos Hybrid and TD5INSIDE map + Allisport IC and a few other bits. I love it especially the turbo and the noise it makes!
Probs hitting 200bhp maybe 500nm or so. Must get it on a dyno soon |
Gerry Member Since: 22 Oct 2017 Location: north Ireland Posts: 35 ![]() ![]() |
I wouldn't mind hearing your dyno results as I have a similar setup here.
So were your tunes specific to your exact setups or just a generic tune and now you have a better turbo to help it?
Mine was a TD5Inside remap done by Jose specific to my Defender, he remapped it then went for several spins before tweaking the remap and turbo boost, however at that time it was just standard equipment but I've since fitted an uprated intercooler and turbo therefore i need the remap and boost pressure tweaked again so I've been in touch with Jose to do so.
Yes my map was VGT specific from IRB. As above, se went for several drives as Ian uploadaed different maps. Most were the same power, but each one felt a little different. I just chose the one that felt "best" for my vehicle. |
i already have a JE tune+ on mine. allisport I/C etc just want to go to the next level. Ive Seen various turbos just wondering whether to fit 1 and see how it works with the current mapping or pay the big boys even more money fitting they're own spec turbo and map
Bespoke map. I fitted everything then had it mapped by Jose had it tweaked a few times but now running very well boosting roughly 26psi. Also got an Eco map and Daily maps changed via Nanocom. |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
VGT - garrett 23 (modified fins)
Large inter cooler - serck motorsports Silicon hoses Map - self map (using tuner pro via nanocom) t box gearing ratio - 1.222 decat - say no to stuffing a cat into your exhaust, that's just cruel straight thru - except for the tail pipe muffler Well, i would say it's worth the effort. You need the larger intercooler if you are on a VGT setup. As you are trying to push more cool air into the engine, but then you will also need more fuel into the cylinders. The theory is simple, more air + more fuel = more bang in the cylinders. But you don't want to be spitting out huge amount of black smoke at all the wrong RPM, rite? sure will get you the wrong type of attention and makes your wallet lighter, be it wasted fuel and a hefty fine. I'm sure there are folks way better at this tuning than me, as I do it purely for fun. Am i happy with the results, yeah, but there's always room for improvement. the turbo whistle and the sound of the exhaust, it's probably as sweet as it sounds. now, in terms of pulling, it's good. uphill in gear 4 without skipping a beat. depending on your driving style and shifting points it feels so much better over the lazy stock tune. temperatures are in the 86 to 88 deg peaking at 92 once in awhile. Now the thing here is that, if it's a spare drive, then sure up the power till it goes bang. you don't want silly figures of power just for a few months and have an engine that will blow up while overlanding or snap the drive line in the wood too. Hence, to say, i'm on the conservative side of what it can achieve. I'm even limiting it to 1.9bar of boost only, most of my driving never even sees 1.5 bar. the stock has a limit of 1.4bar The defender has migrated, leaving the owner behind. |
Interested to hear how you wrote your own tune Achuakh. I've seen the map profile part of the nanocom software but never had a clue how to do it. |
