![]() | Home > Puma (Tdci) > The strip down begins, TDCI head-gasket?? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
![]() Keep us updated, hope you sort it. |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 492 ![]() ![]() ![]() |
Hi Ian, Just abit of thought, have looked at the full length of the liner on Cylinder 4? .....Well what's visible as I have had cracked liners on Gen sets (albeit alot bigger capacity) Andy ![]() |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Hi Andy
I’ve had a good look at the block and bores, I’ve even had my magnifying glass out! , like you say (as far as you can see) As you well know, the only way to be 100% is to pressure test the block, But I really don’t want to go down that road yet! ![]() To be honest, if it was that? I can get a short recon unit for £1100, which would be the way to go, I wouldn’t mess about with mine. The guys who did the head said they would be very supprised if the block was at fault, They said the only issues they have with them, is if it’s crank related. I think I’ve done all I can for now, I’m replacing the pump and thermostat just so I can say it’s been done, I will also back flush the matrix, block, and rad. Fingers crossed ![]() Just incase anyone needs any work done, I can thoroughly recommend these guys, Their workmanship is spot on, and the workshop is on another level. ![]() ![]() http://www.hthoward.co.uk/ ![]() Wanted, Forward Control Anything considered. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Interesting thread.
Did you find out if these heads can be skimmed further than what you have done? thanks Puma 110" SW ............................................................. Earth first. Other planets later |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
I notice on their website they say they only take work from trade customers, not private. |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
Sounds exactly the same as when mine went a few months back...
unfortunately i had to go back to work so its only done the 300 miles or so back from alive to home... have some pics i can upload when i get a chance. |
Today I put the TDCI back together.....
Headgasket on, this is the 3 hole gasket, which is the thickest you can get. The marker holes are above where the high pressure pump is. ![]() Click image to enlarge Nice clean skimmed head.... ![]() Click image to enlarge Head on, full set of new bolts, all 18 are single use on the TDCI. ![]() Click image to enlarge Next, making sure every thing is clean, a squirt of oil here and there, and drop the cleaned cams in place, Insert timing pins back in the location holes. ![]() Click image to enlarge Next, fit the rockers, using new bolts on the carrier frame. ![]() Click image to enlarge Time to fit the tensioner, cam sprockets, then the chain and guides, Using the gold links to line up with the arrows on the sprockets, the fuel pump sprocket has a recessed mark to line up the chain. The tension is held back off the chain until the pin is pulled out. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Always leave the cam sprockets, and pump sprocket bolts loose, before pulling the tensioner pin, This allows the sprockets to move back slightly to lose the slack. If you don’t, this is what can cause the chains to jump a tooth. Front cover on, oil seal in, and starting to look like an engine again. ![]() ![]() Click image to enlarge The Puma carries Possibly the longest aux drive belt I’ve ever seen, other than on a Scania! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Oil and filter change and all done, considering it’s been stood for a week with the fuel rail and lines off, It started quite willingly, I let it sit for half an hour on tickover, while I kept an eye on the water. ![]() Click image to enlarge ![]() Click image to enlarge A quick run around the block, pulled over to look under the bonnet and it seems ok, apart from the ![]() ![]() So I returned home to have a propper look, it’s Odd for a genuine Ford one to weep? I took it back out, and it appears to be the timing chain cover? Stupidly, if I do these at work I always get a genuine seal, and cover. Guess who thought he would save himself a few quid and brought a genuine seal, and non genuine cover, The pressing isn’t that clever around the seal, and it’s pulling it away to one side. ![]() I will take it off tomorrow, and get a genuine Ford cover on Monday. Hopefully that should be it?? ![]() Regarding the skimming, I’m not sure how far you can go on the TDCI? The chap who do it, did say 10 thou was quite deep, and they wouldn’t go much more than that. ![]() Wanted, Forward Control Anything considered. Last edited by ian series 1 on 7th Jul 2018 9:41pm. Edited 1 time in total |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2277 ![]() ![]() |
Ian
Thanks for an awesome detailed strip down and rebuild ![]() Keith |
Good work Ian, so after a drive round the block .....Are you still thinking to sell?
Andy ![]() |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1874 ![]() ![]() ![]() |
Glad to see its back up and running. Hope it's cured the issue.
Cracking write up ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Good write up. Think I'll go back to a push bike now.... It's easier to work on. Seriously top notch rebuild
Cheers guys,
![]() I don’t think anything like this has been covered on the forum? So it’s always good to have some sort of record. I could have gone into so much more detail, but the thread would have ended up like a Haynes manual! ![]() Plus I just don’t have the time... ![]() Andy, I’m really not sure what to do with it? I had a mint low mileage TD5 Disco metropolis before this, the H/G went in that, I did it, and sold it. I think this one might go the same way? Not sure yet ?🤔 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Out at 6.30 this morning before it got too hot!
Stripped out front cover again. ![]() Click image to enlarge Found the culprit! ![]() ![]() Click image to enlarge The cover had a slight dish on the lip to one side, which was pulling the seal to one side, not worth trying to straighten it, Cheap crappy parts, never worth the hassle ![]() I will order new genuine Ford cover, and another seal tomorrow, Plus the 3 crankshaft pulley bolts, as they are only supposed to be tightened 3 times. Don’t want to be breaking one of them off in the crank!! ![]() Wanted, Forward Control Anything considered. |
