![]() | Home > Td5 > Power loss |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 97 ![]() ![]() ![]() |
Sounds like operator driver error
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
On any other i would agree, but this is a first. I was stuck with a 10p for a few months, and it has the same plaguing problem. Sweet spot was 2250.
I will check the wastegate actuator as its directly connected to the reference tube. |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
How long had it been running well for? Days weeks months?
It ran good for a few days,
I try and drive my defender in between breakdowns and parts supply... |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3243 ![]() ![]() |
I had to have my Alive remap removed as it didn’t run properly.
Check turbo/pipes, was the engine overhauled prior to fitting? Is the FPR and prongs/copper washers ok? Any oil on the injector loom? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
