Home > Td5 > Slow TD5
Page 1 of 3 123>
drinkdrinkdrop
Slow TD5
My TD5 currently appears to have a top speed of 76, I'm pretty sure this is lower than it used to be. Also seems a bit sluggish on hills.
Turbo actuator seems to work as expected and I've tried running without a MAF which seems to make no difference. I'm not getting any missfires or anything like that and having recently replaced most of the fuel system I can safely rule that out as the cause.
I suppose my question is, is this the normal top speed for a TD5? and is performance being the same with and without a MAF a sign that it's failed?
thanks in advance
Post #715636 2nd Jul 2018 11:02am
Clean both the MAF and MAP and see how it goes. Wear gloves, keep it really clean and don’t touch the elements. Leave to dry really well on a clean sheet of printing paper. A quality brake cleaner spray though should do the trick. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #715637 2nd Jul 2018 11:16am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Re: Slow TD5
thanks in advance
Might just be the hot ambient air temps we're getting. The standard intercooler will not reduce the temperature of the air passing through it sufficiently, that reduces air density going into the engine which, in turn means less oxygen in the cylinders so less fuel is being burnt.
TD5s seem to be particularly prone to this, especially with the standard intercooler. A bigger aftermarket intercooler can help. After upgrading ours to the biggest we could fit (allowing for our auto gearbox oil cooler) it made a big difference to the available torque, especially in hot weather.
Either that or just wait for the temperatures to drop and it'll be back to normal Smile http://www.yorkshireoffroadclub.net/
Post #715641 2nd Jul 2018 11:32am
grafty99
Have you checked your air filter and associated pipe work? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #715698 2nd Jul 2018 7:11pm
Djcla
Mine won't go above 76 I thought it was normal tbh
Post #715731 2nd Jul 2018 9:12pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I don't think the hot ambient temperatures would make that much difference. When I went on family holidays in my parents '99 disco 2 td5 to Italy and back dad would hoon it on the italian motorways and it'd hold 90mph no problem fully laden. I know discos have a bit more grunt from stock and the different drive ratio but nothing seemed to slow that bus down.
Post #715740 2nd Jul 2018 9:37pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Mine will easily do 85-90 even in the hot weather 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #715743 2nd Jul 2018 9:50pm
drinkdrinkdrop
Filter looks fine but I will swap it anyway and I ran it without the pipe to the wing but didn't make any diference
I've cleaned the MAP already but not the MAF so i'll give that a go
Post #715825 3rd Jul 2018 10:43am
mk1collector
Check for oil in the red Ecu plug. Ray
My build thread
Post #715831 3rd Jul 2018 11:14am
drinkdrinkdrop
Red plug is clean, checked and cleaned a couple of months back while fixing another issue (injector harness replaced at that point as well) so all good on that front
Post #715832 3rd Jul 2018 11:19am
Djcla
I checked mine a while back performing similar steps to you and couldn't find anything obvious. I found the MAF made no difference if it was connected or not and I believe that indicates it's faulty but I wasn't sure.
Post #715846 3rd Jul 2018 12:07pm
bankz5152
Got any diagnostics?
Inlet could beblocked
Post #715857 3rd Jul 2018 12:55pm
drinkdrinkdrop
Had diags fairly recently and nothing on there apart from the usual missing ABS etc, no engine light on. Where would I check for a blockage? I've had the inlet pipe to the airbox off and I checked the inlet manifold recently when I removed the EGR. Any other spots to check for a blockage?
Post #715859 3rd Jul 2018 1:01pm
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
When you say the turbo actuator seems fine, have you disconnected the actuator from the wastegate and check the operation of the wastegate? I’d recommend doing this, and ensuring that the wastegate is so free that it will return to centre on its own when released. Copious amounts of a decent spray oil and loads of working it back and forward should help.
Sounds like the symptoms I was having with a sticky wategate.
HTH,
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #719528 24th Jul 2018 9:58pm
Martin 01
What did you end up doing to your wastegate Jon ?
Just spray it with lots of lube ?
Post #719536 24th Jul 2018 10:18pm
Page 1 of 3 123>
