Home > Maintenance & Modifications > Warranty up, reccomend me....
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
As a rule if I need a tool I'll buy the best I can afford & I'm talking grease guns & grease for the props on the 110. I know absolutely nothing about both so any links / advice gladly received.
Post #715521 1st Jul 2018 5:58pm
lohr500
If you have an airline then consider an air powered cartridge grease gun.
It makes life very easy if you use in conjunction with a flexible pipe and needle point type fitting.
One hand to push and hold the needle point injector into the ball on the grease nipple and the other to squeeze the trigger on the grease gun.
I find the needle type injectors are better than the ones which grip the grease nipples as they need less space. Especially when greasing LR prop UJs. But difficult to use if you have a manual lever type grease gun as you then need three hands!!
Just my preference, but others may well say the grip on type fittings are better.
As for grease, on UJ's I just use bog standard universal lithium grease cartridges from our local agricultural machinery/ John Deere dealer.
Post #715546 1st Jul 2018 7:18pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
If you google grease gun, there are a few recent threads.
here is one to start with... http://www.defender2.net/forum/topic54211.html? Thumbs Up
or this one has a photo of lohr500's air powered Thumbs Up http://www.defender2.net/forum/topic54685.html?
Post #715555 1st Jul 2018 7:59pm
lohr500
Thanks apt100 for posting the link to the topic where I mentioned the air powered Draper grease gun.
I forgot I had mentioned it before. (must be an age thing!)
Don't be put off by the Draper brand Timcat. It has been 100% reliable despite being dragged around the garage floor and dropped a few times. Quick search on t'internet and it looks like they can be bought for around £30.
It worked a treat last weekend when I serviced my 110.
And this is the sort of thing to replace the "grip on" fitting :
https://www.google.co.uk/shopping/product/...lsQ8wII5QI
Post #715559 1st Jul 2018 8:23pm
Zed
Edit
Post #715569 1st Jul 2018 8:56pm
Timcat
Many thanks for the reply’s, will pick one up...
Post #715763 2nd Jul 2018 11:11pm
