![]() | Home > Puma (Tdci) > Puma cabin air intake system Please Check |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17799 ![]() ![]() ![]() |
It is curious how it seems to be a recent problem only. On my '07 these parts fit perfectly and there is no gap in the joint at all.
So given that all the parts are the same, how come some are such a terrible fit? I would have thought that careful assembly should improve the fit. They are definitely not all like that! |
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 ![]() ![]() ![]() |
Same issue as mentioned by others, on my last visit to the dealers, now using Shuckers of Ludlow, they doubled up on the foam gasket and I now have a good seal between the intake and heater head unit..... at long last. As to whether my foot well water leak has been cured only time will tell.....
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 202 ![]() ![]() |
Apart from doubling up on the gasket - has anyone got any other solutions to this?
I have seen this other thread, but not sure if the part mentioned in the picture works on a puma. http://www.defender2.net/forum/topic47380....twell+leak I have a leak on the passenger footwell mat, but only in severe downpours (& only happened after about 8months of ownership) - I am sure that its coming in via the engine bay/under the bonnet and that gasket is soaking wet. I can get my finger in the gap along the top - the parts are not held together firmly at all. I was thinking about a second gasket or taping along the top. and maybe adding another one of those plastic water deflectors that pumas have at the top sides of the engine bay - a bit further down. must be a better solution?? |
![]() Click image to enlarge I've had a leak via the air intake grill which appears to have been sorted by doubling up on the said gasket..... However I have a further leak which appears occasionally and as shown in the photo.... removing the speaker housing I traced the leak to windscreen where the vin label is mounted. I have packed some kitchen roll down there and it comes back soaked but stops the leak into the foot well.... There is no obvious place water is entering on the wind screen gasket.... It is going back to the dealers under warranty on Monday week.. Dave |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20859 ![]() ![]() |
I found poking around the other day I have this issue too.
Does anyone have the P/N for doubling up the gasket or did you go for a homemade solution? I think it has been the source of a bit of a leak on mine, as well as poor efficiency in use of the cold air duct. Never seemed as cool as it should be which I noticed, as well as one of the drain plugs is missing and the remaining drain plug was blocked. So it's drawing in more warm air than cool! Advice welcome from those who cured it if possible please. LR I wouldn't even contemplate speaking to on such things.. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
I'm interested too . Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Here is the seal required.
![]() Click image to enlarge _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks !
![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
I done mine today, it done the job and is much better inc replacing a missing drain valve too.
Gasket on gasket isn't a 100% perfect fit, but it's 99% better than it was, and putting my hand around with the fan on full with the dual gasket I couldn't tell any airflow leakage. And for the first time you can feel and hear airflow being pulled in from the wingtop vent. No wonder it was drawing in warm air. ![]() Click image to enlarge _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
Steve, how did you manage to fit the extra seal?
Mine has a gap, on the bottom and inside edge. I've looked at doing the same but the space available is extremely limited, even with loosening the the ducting from the wing. Did you remove the blower or entire wing, but seems like it is a huge job either way? Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
Jimmyjamesj Member Since: 31 Jul 2021 Location: Sydney Posts: 4 ![]() ![]() ![]() |
Did you end up solving this? and did it solve any water ingress? I have just some across this and I have the exact same issue |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3713 ![]() ![]() ![]() |
Had a look at mine today and the same, big gaps all round the engine side. I had noticed the noise coming in but just assumed it was normal landy stuff. I attempted to get the duct out and put extra gasket on by there was no way it was coming out. Instead, I wedged it right in place and got the heat gun around the duct then let it cool. It’s a lot better but still not perfect so will have another go next weekend.
The result:
![]() Click image to enlarge It’s not as tight as I’d like, but it is sealed all the way around. There is now quite a kink in the duct in order to line it up. ![]() Click image to enlarge |
