Home > Puma (Tdci) > The strip down begins, TDCI head-gasket??
Page 3 of 8 <12345678>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Bit more this morning,
Got all the pulleys out the way, and got the timing chain cover off,
I’ve noticed it’s not an original Cam chain, and guides, also on timing the engine up the marks were not lining up with the arrows on the cam shafts, or the high pressure pump?
They were one link out, not sure why it was done like that?
This would also explain why some of the cover bolts were quite loose, and a Ford part no sticker on the cover.
Anyway, all off and stripped, time to remove the cam carrier,
I gave mine a good look over, as they are prone to cracking around the bolt holes.
Luckily mine seems ok Wink
Next remove the 2 cam shafts.
Finally undo the head bolts and lift off.
Nothing sinister came to light, although I suspect No4 cylinder was the culprit, the combustion marks on the piston crown were quite different from the others, and the carbon build up was a lot darker, the head gasket seems to be ok?
I dropped of the head to a local firm, for a pressure test, and possibly head skim if it’s needed?
Should be back by Tuesday.
I came back and started to fit the new crank sprocket, cam chain and guides
can’t do much else now until I get the head back.
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #715317 30th Jun 2018 2:12pm
Very interesting thread.
Quite a cramped complex engine in comparison to a Td5
Post #715324 30th Jun 2018 3:47pm
CaptainDan
Australia 2013 Defender 130 Puma 2.2 HCPU Alaska White
Hi Ian
I am following your story with interest as I have the very same problem with my 130 and at the crossroads as to what to do. Having spent $8.8k AUD on the repair after the EGR cooler failed and having replaced in the last week the split radiator water pump and thermostat I am at a loss as to what to do next. I have a few options, everyone who has looked at the problem have told me its another cracked head or head gasket, the repair is only 20k old.
If I take it back to the original repairer who are denying the head/gasket problem and they take the head off as you are doing and find that it is nothing to do with their original repair work then I will be in the position of having to pay again for their work and still have a stripped engine I have no confidence them anymore. I am thinking of a new engine and just keeping the original for parts and putting in a brand new one
What are you thinking with the No.4 cylinder?
Thanks
Daniel
Post #715424 1st Jul 2018 5:24am
ian series 1
Hi Daniel
It sounds like your having some bad luck with your Defender!
The most annoying thing is still not being able to pin point something for real?
Like I say, the combustion pattern on number 4 does not match the other 3 cylinders that well,
So I’m hoping the gasket failed around number 4 cyl, and my eyes can not see it!?
If the head comes back ok, I have no option other than refit it and keep my fingers crossed,
I will flush the block, rad, and martrix, and like you replace the thermostat and pump, just so I know it’s been done.
I am taking no chances with this, simply due to the amount of work involved stripping and refitting everything,
It’s not a great engine to work around in situ.
If I still have problems, then I would say it’s the block, in which case I would be looking at a short recon motor,
I do have a 160,000 mile spare engine, but I think the way to go would be reconditioned, then at least there is guarantee on the block.
I’m just glad I can sort this myself, I certainly wouldn’t want a garage bill for this repair in the U.K.!
My cost is around £350 at the moment, most of that being the cam chain kit.
I will certainly keep this thread going until I’ve found the cause, good luck with yours, and I hope you get it sorted soon?
Ian Thumbs Up 80" 80" 86" 88" 90"
Post #715427 1st Jul 2018 6:44am
ian series 1
Good news!
The head was ok with the pressure test, and no warping.
I have still insisted on a very light skim, and re cut the valve seats, just to be sure that I’ve done all I can!
Head kit came today, along with head bolts, rocker carrier bolts, water pump/thermostat, crank sensor, and all the gaskets.
I’m picking it up Thursday night, so all being well I hope to be up and running on Saturday. Thumbs Up 80" 80" 86" 88" 90"
Post #715930 3rd Jul 2018 6:37pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Great work Ian Thumbs Up
I will be waiting with anticipation on the weekend to see how this goes. Makes my issues seem minor Laughing Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #715973 3rd Jul 2018 9:59pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Reading the thread with interest. Wishing you the best outcome. Cheers Don.
Post #716045 4th Jul 2018 10:13am
ian series 1
Cheers chaps,
Fingers crossed I covered all bases on this one,
Hopefully I can report back on Saturday as being a success?
The annoying part is, I’ve found nothing really wrong with anything Big Cry
9 times out of 10 you can see the problem with H/G failure.
I would have preferred to have found something that stands out, but sadly in this case nothing!
The mating surface of the head had 2 tiny marks on it, (and they were tiny!) which is why I’ve decided to get it skimmed.
Anything after this would indicate the block to be the issue.... Rolling Eyes 80" 80" 86" 88" 90"
Post #716052 4th Jul 2018 10:38am
CaptainDan
Hi Ian
Ok so the head is good but what are you going to do about cylinder 4? is that why you have has the valve seats ground? my 130 is still running ok just still loosing coolant from the overflow bottle cap. Should be doing the chem test this weekend.
Just got it back today after having the clutch repaired one of the double springs in the clutch plate had come adrift and was thrashing about inside. What else can go wrong? I have to sort out this cooling issue though.
Daniel
Post #716054 4th Jul 2018 10:46am
Stacey007
Hi Ian,
That looks a bit scary all in bits so hats off you know what you're doing and saving labour rates Thumbs Up
I'm happy with doing basic things like oil changes on my series.
Hope you get it sorted.
Post #716060 4th Jul 2018 11:43am
ian series 1
Daniel
Number 4 was the cylinder with an odd combustion pattern, if any water was entering the bores, I’m 99% this was the one?
The bore looks good, as does the top face of the block,
Obviously it’s only a visual check though.
I can only hope now, that what I’ve done will be enough to cure the problem? Rolling Eyes
Scott,
It’s just nuts, bolts and chains assembled in an specific order... Laughing Thumbs Up
I’ve already been looking at its replacement... Mr. Green 80" 80" 86" 88" 90"
Post #716078 4th Jul 2018 1:03pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Well, in defense of the Puma, I've heard of a lot more head and head gasket issues with the TD5 than with the Puma... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #716083 4th Jul 2018 1:18pm
ian series 1
Your right, h/g failure is almost un heard of on the TDCI,
My local Indy has only ever done one.
I’ve never had any issues on the Transits I repair either.
I did my TD5 Disco just before I sold it, which was typical! the plastic dowels had broke causing the head to move,
Same as what happend with the K series engine in the Freelander's
Both victims of Another wonderful LR cost cutting exercise! Rolling Eyes
You can hear them now.....
Head gasket dowels, Mmmm plastic or steel? Plastic or steel?
Sod it, Plastic it’ll be fine. Big Cry 80" 80" 86" 88" 90"
Post #716085 4th Jul 2018 1:28pm
Hats off to you Ian, that is some real in depth precision engineering work there involved.
Just a suggestion and you may do so anyway, but when you do fit everything and fire it up perhaps you could try some Millers diesel additive too? That should help clean things through especially the carbon deposits over time.
I run it all the time and it's pretty good.
It's been known before for some of the sprockets to have a tooth worn or even missing too.
But most instances are pretty rare.
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #716089 4th Jul 2018 2:10pm
ian series 1
Steve,
Believe it or not I do use it, but looking at the injector tips, and piston crowns,
I don’t think I will bother anymore!
I even gave it a double dose the night before, as I was doing a nice long run.
The internals are no cleaner than any plant equipment I’ve stripped that just runs on red diesel every day.
I’ve seen a few bad chains and sprockets, I did a 2.2 Transit a few weeks ago,
Only done 116,0000 miles Shocked
Post #716092 4th Jul 2018 2:25pm
