![]() | Home > Off Topic > USB chargeing. 12volt or 240 volt efficency. |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 208 ![]() |
Converting from 12v to 240v and then back to 5v is a very inefficient way of doing it, as you say...
Can't you get a 12v USB charger to power all your devices up? If you don't have a cigarette lighter socket in the van, then something like: https://www.amazon.co.uk/Inverter-Regulato...071RKBH82/ Add some crocodile clips / ring terminals (or whatever 12v sockets you have in the van) to connect it to the leisure battery and an appropriate fuse and you are off... |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
I'm not sure if there would be a difference between 12v or 240v, it's more likely to be the maximum output current your USB socket can deliver.
Many sockets have a maximum of 1 Amp for changing, while many of the new devices can draw up to 2.1 Amps. I've fitted some USB sockets under each of the back seats for the children to be able to charge their phones etc. I made sure that they can all deliver 2.1 Amps. There isn't a noticeable difference in changing rates between the 12v sockets or the mains sockets that they use in the house. If they plug it into one of the 1Amp sockets then there is a real slowdown in charging, and again the slower speed is about the same for 12v or 240v. Using an inverter to power the USB charging will have losses on route as you're going from 12V dc -> 240ac -> 5V dc. Just my thoughts and observations. |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1066 ![]() ![]() ![]() |
If you're running a hair dryer for 20 minutes a day, any gain relating to charging a mobile phone is going to be minimal!
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I hadn't come across those, interesting one of those connected to two Power blocks and I have six outlets. the Power Blocks can recharge overnight and during the day when not needed. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
As most commercial sites are 10 amp supplies its a low amp consumption dryer or she can use the 12v dc one. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Why do you need the power banks in the mix?
You have two gigantic power banks already in the leisure batteries - just plug the devices straight into those USB chargers and you skip a step? Only advantage the power banks give you is portability... |
The two Power Banks have already been purchased now and will give the facility to charge 6 items at once instead of two as in the past i.e.2 phones, 2 MP3 players with headsets, 2 e readers. Don't make old people mad.
Ahh, OK.
So plug the power batteries into the 12v USB converter, then all your devices into the power banks. You may find that some devices charge more quickly directly plugged into the converter - but it's down to the power banks and how much current they can output. That'll be a bit of trial and error (and possibly looking at the device to see if it thinks it's charging via USB/cable (slow), AC (faster) or fast charging (quickest)). |
I haver taken the gamble and bought a couple of those items from the shopping site and will see how they go.
Thanks Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
