Home > In Car Electronics > Wiring help for 12V battery to sockets?
Imax
I am getting a 12V leisure battery wired in soon. As part of this I am also adding a couple of 12V and USB sockets to run a cool box and other things I may need for short trips away e.g. phone charging, iPad etc
Is anyone able to advise what gauge wire I need to run to the 12V and USB sockets? I know it is twin cable I need for the positive and negative.
Below are the power figures for the Waeco CF-26 cool box I am looking for...
Power input
approx. 35 W
Current consumption
0.44 Ah/h at +20 °C ambient temperature, 0.67 Ah/h at +32 °C ambient temperature, both at +5 °C interior temperature
Post #714721 27th Jun 2018 1:01pm
rallysteve
I suggest a 20A power socket (like a cigarette lighter) with a 20A fuse and 2mm^2 thinwall cable.
Post #714726 27th Jun 2018 1:07pm
As above an the Bluesea sockets are very good. 👍🏻 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #714727 27th Jun 2018 1:09pm
Imax
Thanks for the info - Looks like I might go with recommended 12V sockets you suggested. I did get some others but the Bluesea sockets look good.
Post #714768 27th Jun 2018 2:46pm
I love the way the current draw is quoted in Amp-hours per hour! That would be Amps, then.
Post #714785 27th Jun 2018 5:14pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
OK I am somewhat confused by the Waeco figures.
If it requires 35 Watts on a nominal 12V dc supply that is 2.91 Amps. Is it then saying it consumes 0.67 A in operation?
Seems a low amount for a fridge cooling to 5 deg. Is the 2.9 Amps the draw when it is freezing to -18 ? 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #714791 27th Jun 2018 5:22pm
That's because compressor fridges operate intermittently. The lower figure will be an approximate average. Darren
Post #714794 27th Jun 2018 5:29pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Try this site:
https://www.12voltplanet.co.uk/cable-sizing-selection.html
You can feed in current draw and size of wire and it will give you the voltage drop over distance. Depending how far your sockets are from the battery you may need to go up a size. Always add in a good safety factor on the size of wire. Too many systems are designed with cables sizes too small for the distance and you end up with insufficient voltage / current at the end.
Post #714800 27th Jun 2018 5:56pm
Imax
Thank you for the info - I had a chat with a local company who generally do VW conversions and they said the same regarding the wire. Just need to get my Blue Sea sockets order and my cool box to be wired in on the 11 July.
First short trip planned for the weekend after...
Post #715016 28th Jun 2018 4:44pm
Imax
Leisure battery installed along with some blue sea sockets - the blue sea sockets are much better than the others I had purchased. Also had to purchase a dedicated 20amp socket for the cool box.
Battery has been installed under the new load area which has worked well and they have been able to use existing access points for cables etc.
Post #718714 20th Jul 2018 12:30pm
