![]() | Home > Puma (Tdci) > Vibrations |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17869 ![]() ![]() ![]() |
Any imbalance or defect in any rotating component can cause this. After wheels/tyres, the next thing I would check would be the condition of the propshaft UJs, and whilst I was checking them I would check that I haven't lost a propshaft balance weight.
To check the condition of the UJs thoroughly it is necessary to unbolt the propshafts, so that each joint can be articulated fully. Whilst a really bad UJ can usually be detected with the propshaft in place, a stiff or notchy UJ generally can't be detected without articulation. |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Steering ball joints/drop arm ball joint?
If you move onto the balljoints (as suggested above) also check the swivel bearings for preload - insufficient preload can allow a wheel wobble to develop.
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
You also need to consider the frequency of the vibration, for example, an out-of-balance wheel has a distinctly lower frequency vibration than a faulty prop-shaft UJ, (about 4x in fact.)
olivers Member Since: 19 Jan 2012 Location: Southern Scotland Posts: 115 ![]() ![]() |
Thanks for all the hints, guys! I'll do a lot of checking and possibly pop into the local garage for some help - will keep you posted what I find.
Oli |
Follow-up: vibrations finally gone - well, mostly. It appears the main culprits were the tyres... BFG mud terrains, and it turns out the front ones are slightly strangely worn. On close inspection they appear to be worn more on the inside than the outside, but only on every second tread. It’s unclear how that happened... but with the front tyres swapped to the back, the vibrations are almost gone.
On the way ball joints and prop shafts have been thoroughly checked and several bushes changed - so all good stuff. Plus lessons learned, including how all these bits and pieces have influence on ride quality. |
