![]() | Home > Maintenance & Modifications > Britparts fuel filter. Stanadyne or pattern? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Really worth the risk for a few quid?
Britpart's OEM offering will be fine but the standard pattern one will be cheap for a reason. ![]() ![]() |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Get a genuine one, I had an OEM clog up and caused misfiring etc, local garage replaced with genuine one, told me don’t risk it for a few quid. |
The original Land Rover fuel filter IS Stanadyne (the company is owned by Donaldson) !!!!
The bayonet fixing system is registered by Stanadyne (whole system is called "Fuel Manager" (look at google) and it is probably the best filtering system on the market today. https://www.donaldson.com/content/dam/dona...ystems.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
I have used the very same Stanadyne fuel filter since ever. As well the Mahle oil filter. Puma 110" SW
