Home > Technical > Indicator cancelling tab on 1993 90
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Does anyone know the location or have a picture of tab location on steering wheel? I know it's at 12 o'clock on later models but seem to think it's at 4 o'clock on earlier.
I've removed a non genuine wheel and boss but failed to make a note of location. Embarassed
Post #714437 26th Jun 2018 7:19am
I'm pretty sure it's 6/12 o'clock on all models. I replaced the switch on my '91 90 and the blue collar had an arrow moulded into it (just visible pointing the wrong way on this pic) that needed to point left for it to work. That leaves the slots for the steering wheel lugs top and bottom.
 Darren
Post #714446 26th Jun 2018 8:16am
ginjez
Thanks LRA. I presume you rotated the collar 90° ? That's where I have mine but indicators are cancelling before I turn. I'll try rotating it through 180° and see if that works. Neutral
Post #714535 26th Jun 2018 5:37pm
V8GPC
i have only ever seen the ring top to bottom; even on the early steering wheel the ring was like this. The later cast legs also top to bottom
Post #714544 26th Jun 2018 6:25pm
Yeah, that's right. Although I experienced the same problem where the damn things would cancel almost as soon as I turned in one direction. I did wonder if I'd messed up something inside by turning it away from it's centre position so I tried to reset it but with only limited success, to be honest. Darren
Post #714580 26th Jun 2018 8:59pm
