Home > Puma (Tdci) > Central locking on defender puma
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hi all ihave just bought central locking looms etc to convert my defender,
All the wires was in the bulkhead,is it possible to activate it?
Mine has standard alarm fob.
Thanks Ash
Post #70165 8th May 2011 5:31pm
ickle
Yes but not straight forward. The ECu may not support central locking, you can piggy back a relay onto the board of the alarm ecu, did mine a few months ago, will find details and pictures in the next few days......
Post #70179 8th May 2011 6:24pm
Landyash
Thanks very much ickle
Ash Wink
Post #70193 8th May 2011 9:02pm
ickle
Hi - sorry for the delay, a link sent to me by Diesel Jim was: [url]http://la7dja.org/defender/cdl/ [/url]
This includes all the relevant connections on the pcb - I also picked up the main power & earth off the pcb to power the relay. I also wired a +ve & -ve directly through the interior from the battery.
I'll find the details of the relay I used and post again.
Keith
Post #71412 17th May 2011 9:57pm
ickle
Hi Ash,
Details of relay:
MES 98031
Purchased via ebay from:
Elliott Boddy <travelin>
Wiring details are:
1m & 2 m are the red and blue for 2 wire actuator (i wired these to the output wires)
2 & 3 are negative switching from 5 wire actuator (these are the low current switching wires)
The other is earth
I have a couple of photos of mine though not as clear as the ones on the link above, one day I'll find how to post pictures on here - try as I might I cannot get anything off my c drive into my gallery, I wanted to post some of Ickle in France the other week, tried 4 times with no luck! Embarassed
Post #71417 17th May 2011 10:11pm
Landyash
Thanks for that ickle
Will keep you posted on progress
Many thanks Ash
Post #71830 20th May 2011 5:52pm
PaulMc
ickle wrote:
Hi - sorry for the delay, a link sent to me by Diesel Jim was: http://la7dja.org/defender/cdl/
Keith
The fullsize pictures (2048 x 1536) from Espen S. Johnsen's Central Locking article can be found here -
http://la7dja.org/defender/pictures/
. Paul.
Post #71884 20th May 2011 10:22pm
Landyash
Thanks for that ickle all sorted now Thumbs Up
Got a broken 10 AS unit took the relay out and soldered it in mine Thumbs Up
Works a treat.
Paul thanks for the pictures too Wink
Thanks again Ash Wink
Post #76453 17th Jun 2011 11:18pm
ickle wrote:
Wiring details are:
The other is earth
Ickle.... could you just clarify the wiring connections onto this relay? (i've just bought one for my 110)
1M & 2M go to the actuators in the doors? (aka the solenoids)
2 & 3? where do they go? to the output from the 10AS (the soldered on wires bypassing the non existent CDL relay?)
Earth is obvious. and the +12v feed goes to the +?
cheers Thumbs Up Thumbs Up
Post #78626 1st Jul 2011 8:20pm
ickle
Sorry for the delay router problems for 24 hours!
Yes DJ, you are correct in your assumptions, but which way each pair connects I'm not sure, & I don't know if it matters as its a switching relay, if it works, superb,if not swap the connections around!
If you have problems I'll pull the unit out again and get a proper note of the connections.....
Keith
Post #78730 2nd Jul 2011 6:44pm
Thanks Keith.
I figured as much. like you say, they're just switch contacts so can be reversed (and it also depends in which way i connect in the trigger from the 10AS)
will be doing the job this week... can't wait! Cool
Post #78732 2nd Jul 2011 7:02pm
ickle
I could cope without lecky windows - even air con (if the Puma had screen vents like my 100") but remote central locking is a must........
Post #78738 2nd Jul 2011 8:00pm
