![]() | Home > Technical > Ignition switch wiring help please |
mark13 Member Since: 16 Apr 2018 Location: Essex Posts: 56 ![]() ![]() ![]() |
Sorry I can not directly answer your question but I can tell you a way I would find the answer. First draw a grid 5 high 5 wide three times. Then get the switches on the desk and get a multimeter and check the continuity between each pin on the first switch, marking a cross is each box on the grid that has a connection. Then draw another 3 grids and do the same on the new switch. The pin config will then be obvious when compare the grids.
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 839 ![]() ![]() |
It’s only 2 Switches, managed to double post the 2nd picture
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
What's the part number of the new switch please?
Hi Martin, Part number is QRF100870
Cheers Brad |
New switch is PRC2735 aka Lucas 162SA
Connect as follows: 1: White = Ignition switched out 2: Brown/red = glow plug 3: White/Black = fuel solenoid 4: White/red = starter 5: Brown = battery live in ![]() ![]() |
Many thanks Martin 👍
That’s tomorrow mornings job sorted. Much appreciated !! |
I know you said brown twice in your first post but I am assuming that's a typo and one should be white (old pin 4). If you actually have two browns then the one to your old terminal 4 is the ignition switched out and should go to new terminal 1.
Typo, should read white 👍
Did it work? (fingers crossed!)
Spot on Martin, many thanks I should have posted sooner, your help is very much appreciated. It’s surprising how the small things make a difference. I’d not realised how stiff the old barrel was and it’s nice having a bigger plastic key instead of the old small metal one 👍
Great
