Home > Maintenance & Modifications > Mounting/Demounting RTT
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
It's one heck of a physical task getting my RTT up onto the roof rack especially since i'm having to manage it by myself.
I've been considering ways to make this easier. I'm contemplating making a ramp, some sort of detachable wheeled trolley and using a small electric winch on the roof rack to draw the tent up into position. Before I get any deeper into this idea, has anyone done anything similar? Or come up with another way of installing their RTT?
I already have a couple of ground tents at my disposal and I know the RTT seems a lot of fuss but I don't want to give up it. Any helpful ideas would be welcome. Thank you.
Post #714020 23rd Jun 2018 3:13pm
zsd-puma
I'm not entirely sure what an RTT is, but for putting anything on a roof a couple of A-frames with a a block and tackle will do it. Depending on weight you can knock one up out of 4x2 timber. Either mount it on castors or drive the car under it.
If you have a high enough garage then you can put the block and tackle/chain lift on the roof joists if they're up to it.
Post #714026 23rd Jun 2018 3:41pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
You could also obtain some scaffolding poles and clips to build a frame then use and electric or chain hoist from this.
Post #714031 23rd Jun 2018 4:13pm
leeds
We use an electric hoist mounted on a scaffold swing arm.
Whatever lifting mechanism you use you will need it mounted 4+m high. Could you mount such a system on the side of a building?
One issue with lifting a RTT up is to get it level. Without building a frame to lift it up in, you will need two straps in one direction and another at 90 degrees to prevent it slipping out. What you do not need is to get the roof tent 2.5m above the ground for it to slip out and hit the deck.
Depending on the roof tent and rack it may be easier to lift the rack off, mount the RTT on it and lift the job lot onto the vehicle. I have done this when it has been difficult to get to the RTT fixing points under the rack.
Brendan
Post #714032 23rd Jun 2018 4:21pm
zsd-puma
This is a good shout I think. Would be much easier to build.
Post #714038 23rd Jun 2018 5:04pm
This works for me! Rolling with laughter
Post #714106 23rd Jun 2018 10:31pm
rockster57
Mobile crane is an ace idea - except..... well except for lots of reasons! Anyways, it made me smile. Thank you everyone for your input. I'm still thinking this through. Thumbs Up
Post #714108 23rd Jun 2018 10:39pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
This is how we do ours..
Two straps and slide the tent up the straps to the roof, works when putting it on and taking it off. It helps that we have another Defender to use as an anchor. They are truck ratchet straps, using the ratchets at the anchor to adjust the tension.
I also made a trolley to make moving it around and storing it a lot easier...
 http://www.yorkshireoffroadclub.net/
Post #714110 23rd Jun 2018 10:53pm
