![]() | Home > Td5 > Transfer case - stripped threads - drain plug |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
John,
Halfords do these repair ones which might be a possibility? http://www.halfords.com/motoring/car-parts...lug-hfx693 Not sure if there is enough room for the wings to fold out though. They do a couple of sizes i think. Steve 02' 110 TD5 Double Cab Rebuild Thread |
^^ that's a great find rallysteve
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8324 ![]() ![]() ![]() |
Recap to larger size Cheers
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6006 ![]() ![]() ![]() |
That was a good find Steve, but on opening the spare transfer case there is not a lot of room between the drain and a big gear.
Drain plug seen poking out the side of the case ![]() Click image to enlarge @JSt - Racap/rethread might have to be the order of the day 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Helicoil! 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
That might be the answer.. Not sure how you use them but maybe the answer. 1999 Defender TD5 110
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Go for a time sert, stronger and longer lasting than a helicoil 👍
Do these screw in, hammer in, drill in ? I assume once in, then you insert the drain plug(or replacement)? 1999 Defender TD5 110
Ok, it's probably best if you take it to a trustworthy garage, they shouldn't charge you that much. It saves you from the initial cost of the inserts and fitting kit
I think that is my next move. My normal garage have a good bunch of lads. They get all sorts, classic e type, stags, etc right up-to modern day motor cars and my 110
![]() Regards John M0VAZ Econet Station 48 no clock |
Since I did the temporary fix the car has been fine. Discovered today a ring of oil on the floor under the transfer case.
Car is booked in Monday to get fixed and at the weekend I have a rally! ![]() Regards John M0VAZ Econet Station 48 no clock |
