Home > Maintenance & Modifications > Panhard Rod play.
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Panhard Rod play.
So I noticed some clunking when turning and it turns out there is some play in the Panhard Rod. I managed to get a quarter turn on the nut and that has helped. I thought though that the bolt and Bush were all an interference fit... Is this not the case? V8 90...WIP
Post #713790 22nd Jun 2018 12:01am
Pilgrimmick
It needs to be tight, the tolerances that allow you to fit and remove the bolts mean that there is some play. Can cause horrendous vibration at speed if left too loose. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #713823 22nd Jun 2018 9:48am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I had this on one of my previous 90's, the bolt at the chassis end of the PR had worked loose, I took the bolt out to check properly and found although it was a close enough fit in the bush, it had a groove worn into it from where it passed through the bracket allowing a couple of mm extra movement side to side.
Played havoc with the handling.
Post #713825 22nd Jun 2018 10:12am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
The hole for the bolt can wear allowing movement.
A washer welded in place solves the problem.
Post #713826 22nd Jun 2018 10:19am
