![]() | Home > Maintenance & Modifications > Part manufacturers - again- is there a difference? |
| BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211
I've been through this before with filters but now I've hit the same question as I need a new started motor and a tensioner for the drive belt.
For the starter (NAD101240) there seems to be a number of manufacturers including Britpart, denso, bearmach, quinton Hazelm original equipment, allmakes, and of course Land Rover. The prices vary by almost 10 fold! Is there a difference is the reliability/longevity of these different makes? I don't really feel like getting stuck out in the bush if there is a difference but I also don't need to pay a ridiculous amount for the Land Rover part if there isn't much of a difference. Thanks! Ref: https://www.lrdirect.com/NAD101240-Starter-Motor-Td5/ https://www.landroverworkshop.com/parts/NAD101240 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1661
buy cheap buy twice. we use a lot of bearmach gear as it has a 3yr warranty and is priced fairly.
nothing with a blue bag.... or a recognised brand like mahle. some of the cheap ebay starters are very noisy in use and take much more current than a better brand. |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
What i normally do is to check which brand is the part and then buy it. Saves at least 50%. Or if it’s an engine part i check the ford prices.
I buy only LR parts if there is a compelling reason. a defender from 1984 pretending to be a puma with a touch of Range Rover |
