![]() | Home > Puma (Tdci) > Oil change with extractor |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Has anyone used an oil extractor on a puma?
I’am looking at the pela 6000. a defender from 1984 pretending to be a puma with a touch of Range Rover |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
Whats wrong with undoing the sump plug? You've got to go under to do the filter anyway...
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I've got an oil extractor, but to be honest I've never used it on the Defender. The sump bung is so accessible it's daft not to use it, as Cetane said, you've got to go under there for the filter anyway.
There's no reason it won't work if you really want to, just check the extraction hose is slightly longer than the dip stick. |
It's the antiroll bar, but making sure the vehicle is level helps, it only hits the roll bar briefly, and you can wipe it off with a rag. It's far more messy removing the filter than draining the oil. |
Ive just done mine today. Make sure the bowl youre using to catch it in is big enough. Whip the plug (Quickly) out and there's literally no mess. The oil filter however....
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1341 ![]() ![]() ![]() |
The other thing I learned very quickly with the Puma is not to attempt an oil and filter change outside if there is the slightest hint of a light breeze.
Lol. We’ve moved a year ago. And this is not the driveway where you can have a little mishap since it’s parked in the road. Therefore i was looking at the Pela. Other brands of cars seem to have postive experiences but i can’t find any defender cases. a defender from 1984 pretending to be a puma with a touch of Range Rover
I large drain pan and a large rubber/vinyl/carpet mat laid on the road to catch any drips and you should be fine.
You're still going to have to do the messy bit - the oil filter - on the road anyway. |
After so many positive comments
![]() Just ordered my Pela 6000. And I will keep you informed. Plan is. First drain the oil out with the Pela. Then take out drain plug to check if there is any oil left, so I'am sure the Pela works (or not). a defender from 1984 pretending to be a puma with a touch of Range Rover |
Photos... This needs photos!
Back in the day when I used to swing spanners for a living we used to use something like this when dropping fluids on the deck wasnt an option.
![]() Was just a BIIIG metal tray that was put under the drain tank. You get the idea. |
You mean this?
![]() Unit will be arriving this week (I hope). I will take some photo's of the proces. a defender from 1984 pretending to be a puma with a touch of Range Rover |
No I meant of the job.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17867 ![]() ![]() ![]() |
Why not fit a Difflock drain plug and solve all your problems? See http://www.defender2.net/forum/topic29173.html for more info and links.
I use one since it avoids the need to remove my underbody protection to drain the oil. |
