Home > Td5 > TD5 WIPERS PARK SWITCH REPLACEMENT
Carolos1973
Cyprus
cAN YOU TELL ME HOW TO REPLACE WIPERS PARK SWITCH ON A lAND ROVER DEFENDER TD5 ( WITH AIRCONDITION DASH BOARD)
THANK YOU
Post #712961 18th Jun 2018 8:15am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Ac no different
Remove near side dash end and also dash top
You can reach inside old switch pops up and then unplug and reverse the process to fit the new one 20 min job
Fit a genuine one only other wise aftermarket ones can burn your motor out when they fail 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #712979 18th Jun 2018 12:40pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
For LHD:
1-Undo and remove the two screws on the side of the AC plenum.
2-Unscrew the centre screw holding the unit at the middle by the shifter (but leave it in place )
3- let the unit hang a bit like one or two inches to get at the lower dash wiper moter cover
4- unscrew the three screws securing the wiper lower dash cover and remove it
5- you now have access to the wiper motor and are able to remove it from there.
6- you can reach up, unplug the wires and do what you need to. The park switch is visible and accessible.
Reverse all precedures to put it back together👍
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #712985 18th Jun 2018 1:27pm
Carolos1973
Cyprus
Any youtube links or pics pls?
Thanks
Post #713008 18th Jun 2018 3:53pm
4RF RDS
These should help with screw locations, and component locations. The plug is what the park switch plugs into. I am unaware of any videos. Good luck, its quite easy actually.
1967 MGB GT
Post #713058 18th Jun 2018 7:46pm
Carolos1973
Cyprus
Many thanks i think that will work!!!!!
Post #713116 19th Jun 2018 6:56am
