![]() | Home > Puma (Tdci) > TD5 to 3.2 TDCI conversion |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
the main reason for upgrading a Puma engine to a 3.2 is it's still a Puma engine and will mate up to the existing mountings and gearbox. You'd probably need the Puma speedo, which pretty much means a whole puma dash.
If you want to upgrade a TD5 there are probably better options. Such as a Cummins lorry engine, which could be fitted for the same or less work. Or just sell your TD5 and buy a Puma Defender. |
LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 232 ![]() ![]() |
I thought that the Ranger was not the ideal engine for the conversion.
I believe that the only successful conversions where done with transit engines and gearboxes. Using a ecu from the transit. Starting with a factory puma powered land rover. M & D offer solutions for fitting different engines to the MT82 gearbox and also a 3.2 conversion. I believe they use a standalone ECU to run the engine. Might be worth contacting them? |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
General consensus is it’s nice to say I’ve a 3.2 Tdci, but it’s not actually that great a conversion and expensive. Much better power plants out there.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
Everyone keeps saying they're better conversions, but never say like...? Unless you go full on LS3? Cummins seem too heavy, so what is there? James
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
It’s doable it a cheap conversion if your brave Enuff to do it yourself 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
But you’ve got to have the skills to pay the bills like you Steve!
Maybe so but inc buying the engine I didn’t pay over 5k for my hole conversion ? 2015 2.2 tdci hardtop xs
Last time I pass a compliment
![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
