![]() | Home > Td5 > Td5 oil spec 10p engine. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Mannol 20 Litre 5w30 ZETEC Semi Synthetic
I run the above, right grade, recommended for TD5 by a few people, and £50 for a 20L drum. Still have a bit of an oil leak, but it's always done that... |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I have run Smith and Allen 5w30 fully synthetic oil for the last 4 years and it seems fine. No new leaks, just the usual land rover/td5 leaks
Steve 02' 110 TD5 Double Cab Rebuild Thread |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6020 ![]() ![]() ![]() |
Cheers chaps, My leaks are mainly front cam seal and rear rocker half moon. 1999 Defender TD5 110
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
I run 5w30 fully synthetic, the rocker cover half moon and front cam seals are prone to leaking whatever oil you have in!
When replacing them I use a small smear of RTV silicone and not had a problem since. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
